Does anyone here have the APS ST or TT WITHOUT an engine failure?
Old Aug 12, 2006 | 03:29 AM
urban's Avatar
APS TT
Does your engine have stock internals or upgrades? upgraded
If the engine was upgraded, what was done to it? JE pistons,Carillo rods,cams, Knife edged crankshaft,5 angle valve job,titanium valves,redline removed
What extras have you installed for the turbo in addition to the kit? NA
What boost level are you runnng? 12lbs
What is your WHP (only if known from a dyno run)? 440 whp
About how many miles have been driven since the turbo install?1000K
What octane gas do you use? 91
What octane gas was the engine tuned for? 91
What is typically the highest rpm's you run? 5800
Who did the most recent tune? SP
Are you aware of any cooling issues with your engine? None
Old Aug 14, 2006 | 10:03 PM
APSMike's Avatar
No engine failure here.
APS TT
Does your engine have stock internals or upgrades? stock
If the engine was upgraded, what was done to it? N/A
What extras have you installed for the turbo in addition to the kit? N/A
What boost level are you runnng? 10 lbs
What is your WHP (only if known from a dyno run)? 446 RWHP (DynoJet)
About how many miles have been driven since the turbo install? 12K
What octane gas do you use? 93
What octane gas was the engine tuned for? 93
What is typically the highest rpm's you run? 6K
Who did the most recent tune? JapTrix
Old Aug 15, 2006 | 02:24 PM
GZire's Avatar
2004 G35 6mt coupe
Does your engine have stock internals or upgrades? Stock
If the engine was upgraded, what was done to it? APS TT, stock plenum
What extras have you installed for the turbo in addition to the kit? APS true dual exhaust, stock cats
What boost level are you runnng? 6-8 psi although I've seen boost creep to 12 psi with an extended run
What is your WHP (only if known from a dyno run)? No dyno
About how many miles have been driven since the turbo install? 4000?
What octane gas do you use? 92
What is typically the highest rpm's you run? 5000, loss of traction above this
Who did the most recent tune? N/A
Are you aware of any cooling issues with your engine? None. Standard oil = 210 F, water = 208 F
Freeman186
Sep 6, 2023 10:07 AM
alessandro
Oct 8, 2015 09:29 AM
Joe Gargano
Sep 18, 2015 11:17 AM
AT23
Sep 15, 2015 07:44 PM
AuAltima3.5
Sep 13, 2015 10:53 AM
