G's w/ T-netics.
Old Aug 25, 2006 | 10:50 AM
  #31
QuadCam's Avatar
Originally Posted by pdjafari
why is it i seem some Z/G's with the T/N S/T but they have Turbonetics stamped on the intercooloer in a blue color (ex. kcobean from my350z w/ the redline Z)???
usually, it says "SPEARCO" in blue on the intercooler. That is another division of turbonetics parent corporation.
My says "spearco" but I flipped the intercooler around so my radiator can read it!
Old Aug 25, 2006 | 01:03 PM
  #32
klg35's Avatar
Originally Posted by QuadCam
here's a quick pic I snapped as I was finishing up my install on the sedan.
allright, after your pic, and seeing how the air filter sits on top of the fmic, i'm ever more so going with TN st, and the fact of the 1 year no hassle warranty doesn't hurt either............funny thing was that i saw a sedan where they cut, that's right, cut, chopped off a little portion of the front bumber beam to make room for the air filter
any luck on the banging/clanking thingy when off throttle and how's oem ecu doing?
Old Aug 25, 2006 | 01:23 PM
  #33
QuadCam's Avatar
i figured out the majority of the clanging was coming from the v-band clamp on the joint between the downpipe1&2. I reoriented the clamp and now, it's fine.
Old Aug 25, 2006 | 01:35 PM
  #34
escobar929's Avatar
nice Andrew didnt know you actualy went w/ the TN kit, is this a kit for the rev-up 350z?
Old Aug 25, 2006 | 01:54 PM
  #35
QuadCam's Avatar
no...it's a regulaer Z tuner kit. "they said it's all the same," but there are only a couple differneces. you need to dimple (hammer time!!!) one pipe that hits on the front cover and I needed to get a slightly longer section of silicone hose coupling. (thank goodness for amazon hose in Miami!)
Old Aug 25, 2006 | 11:01 PM
  #36
2slo2bfurious's Avatar
There's clearance for the intake there?? How come you didn't do it in the position where the manual showed, or is this a difference between sedans and coupes?
Hmm....wonder which position gets more air..... or cooler/warmer/more-less dirty air....
Old Aug 25, 2006 | 11:54 PM
  #37
QuadCam's Avatar
I bought the Z kit. it is about $500 less than the G kit. Basically, I didn't want the fans and controller for the intercooler...so why pay for it.
Plus, I like the intake tube on the Z kit better than the G. On the TN G kit, they have this very tight (restrictive) 90* radius rubber piece. plus, it puts the air filter down low. I have never been a fan of low air filter mounting. We get alot of rain and deep puddles in the streets here in Florida. Today is a perfect example. I'm glad I didn't have my filter at the bottom of the fender well after today's rainstorms!!!
Old Aug 26, 2006 | 10:15 AM
  #38
JDM 350GT's Avatar
why not APS ST?
Old Aug 26, 2006 | 11:26 AM
  #39
QuadCam's Avatar
here are the instructions for the G35 Coupe:
http://turboneticsownersclub.com/turbos/Gkit.pdf
there are good pics in there.
also, check out www.turboneticsownersclub.com you'll have to register to see pics, but you can't alot on there...especially, the new overboost wastegate relocation pipes.
Old Aug 26, 2006 | 11:07 PM
  #40
QuadCam's Avatar
Originally Posted by JDM 350GT
why not APS ST?
never really looked into it.
I heard lota of bad things about oil issues, low boost and overboost problems, etc. plus, do they make a tuner kit? and finally, it looks so cool to pop the hood and see the turbo and bov ont TN!!!!
Old Aug 28, 2006 | 02:16 PM
  #41
klg35's Avatar
part number of that longer silicon hose coupling? working on my shopping list thanks.
btw, did you get a chance to tune it yet, or still putt'n around?
Old Aug 28, 2006 | 03:58 PM
  #42
QuadCam's Avatar
slowly tuning it.
I am doing alot of part throttle tuning trying to keep the UTEC in a single "load site." it is very tempting to go WOT!!! I have the loadsites setup so that I have a 1 psi resolution per load site.
Old Aug 28, 2006 | 04:15 PM
  #43
turbonetics-g's Avatar
i got it in January 2006 $4500.00 ! ! !
Wish i got the Greddy or JWT twin kit instead. They are rated at nearly 420-450 hp. Turbonetics is only 380ish hp.
TIPS:
Do not tap the block for oil- use the "sandwich" between the oil filter & block
Other that that- The kit is very satisfying
Old Aug 28, 2006 | 05:46 PM
  #44
klg35's Avatar
anything over 400+ hp would best be handled with built engine....and of course deeper pockets........
i have the water/meth injection kit that i'll be installing for extra protection as well.......imo, 360-380sh rwhp is plenty enough as a dd w/stock internals, for me anyways......
