Stillen Stg2 Pulley Color
Old Jul 7, 2006 | 01:53 PM
mokc's Avatar
Is anyone running a stg2 in an 03 car year? What color pulley are you suppose to have? I have a red pulley which is suppose to be a stg3, but some say it is a stg2, so which is it?
Old Jul 7, 2006 | 01:56 PM
ttrank's Avatar
Grocery getter
For my 04' stage 2 is blue, stage 3 is gold and stage 4 is silver.
I know the 03's are different so just call Stillen, VRT, or Performance Nissan.
Old Jul 7, 2006 | 03:44 PM
mokc's Avatar
Well...just trying to get a consensus of what is out there since when I asked Stillen, they tell me that the stg3 is the red pulley for the 03 model, but stillen did my install for a stg2 on my car. Go figure!! Although i know it is a stg2 because i am not making anything over 6 pounds of boost.
Old Jul 7, 2006 | 04:05 PM
superchargedg's Avatar
for 03 stage 1 and stage 2 pulley are the same (black) stage 3 is the red pulley.btw i would not even bother with stage 3 its a joke,just go straight to stage 4 huge difference.
Old Jul 7, 2006 | 04:09 PM
mokc's Avatar
Hmm!! That's interesting then. I have the red pulley that Stillen installed for me, but they claim it to be a stage 2. Now i'm really confused!! Yeah...probably just blow off the stg3 and go to the stage 4. Here in CA we have to worry about the smog thing. Any luck we can pass the sniffer test with the stg4?
Old Jul 7, 2006 | 11:53 PM
Skyline_G35's Avatar
English dude, English
is your 03 an auto or manual???
Old Jul 8, 2006 | 01:37 AM
mokc's Avatar
I have an 03 manual.
Old Jul 11, 2006 | 12:02 PM
ttrank's Avatar
Grocery getter
Not sure but the pulley is easy to change so you could put the stage 2 back on when you get tested.
Old Jul 11, 2006 | 12:23 PM
mokc's Avatar
Can you run the stg2 pulley with the stg4 upgrades? I would think that you can, but just curious. How does the FMU work? What are variables used to make the 7th injector work? Is it based on pressure? Also do you need a pulley thingy(?) to remove the pulley?
Old Jul 11, 2006 | 01:12 PM
you would run pig rich and fail any sniffer test.my pulley was quite hard to remove dunno why,it was like pressed on the shaft.even when i changed to the stage 4 pulley i had to use a much longer bolt to pull the pulley onto the shaft.
Old Jul 17, 2006 | 01:42 PM
ttrank's Avatar
Grocery getter
I had a hard time getting my stage 2 pulley off when I went to 3 but 3 to 4 was very easy.
As for using the stage 2 pulley with the stage 4 mods, I don't know how rich it would run since the SS box adds fuel based on boost. It might be just fine. If you have a A/F gauge you could check. My A/F has been about the same between all stages (a little more lean with 3 but well within safe limits).
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
