Greddy TT on Rev-Up w/ stock internals
Old Jul 11, 2006 | 10:47 PM
Dr_jitsu's Avatar
GZire: Boost, A/F ratio, what is an EGT? also I am thinking some type of oil gauge, especially since the test pipes seem to sometimes cause oil loss
Old Jul 11, 2006 | 10:52 PM
IvoryGT-V's Avatar
I currently have the greddy twin set up and have not dynoed yet but I am loving the boost. I am running the Emanage and your right its not so great. May get a different one soon but it comes tuned for you. So far knock on wood 2500 miles and still running strong.
Old Jul 11, 2006 | 11:17 PM
Dr_jitsu's Avatar
Ivory<
You MUST get a tune if you want your engine to last! Also, you will make more power.
QuadCam's Avatar
can you get a "tuner" (no fuel/engine management) version of the greddy?
Old Jul 11, 2006 | 11:30 PM
Dr_jitsu's Avatar
I swapped the Greddy EU for the HKS. SGP credited me 600 for the EU.
Old Jul 12, 2006 | 12:10 AM
QuadCam's Avatar
where can you find info on the HKS f-con IS?
Old Jul 12, 2006 | 12:31 AM
Dr_jitsu's Avatar
The IS is brand new and only released in Japan. Not available w/ anyone but SGP here in the States, to my knowledge. You need a certified HKS installer. have you considered the UTEC?
What are you looking to do, quad...what are your goals, and what do you have...an 06 6mt?
Old Jul 12, 2006 | 12:39 AM
IvoryGT-V's Avatar
I talked with greddy and an installed no tune is need unless you boost more then 6lbs. Ive done my research and calls to greddy....
Old Jul 12, 2006 | 03:13 AM
draxxus07's Avatar
definetly look into the fuel return if you want to add more reliability to the setup
Old Jul 12, 2006 | 03:25 AM
Disco_Monkey's Avatar
10K for ALL that mentioned is STILL a great deal. Even the 8.7 installed and tuned is a smokin deal.
I'm paying a little under 10 for my JWT TT setup on my non-built 05 Revup motor. I was also offered a clutch/flywheel, oil cooler, radiator upgrade and thermal coating for extra of course as the main recommended add-ons. I also want three guages and a power steering cooler.
So now I am preparing myself for a little more than expected as I was warned by all the veteran TT guys.
Old Jul 12, 2006 | 08:21 AM
dofu's Avatar
20 Year Member
EGT = exhaust gas temperature. IMO, minimum is boost, oil pressure, and egt. The egt will let you know if you're running rich or lean... but an a/f in it's place would be much better.
Old Jul 12, 2006 | 09:29 AM
Dr_jitsu's Avatar
Thanks everyone...will get boost, A/F and oil pressures gauges...probably a fuel return...how much for fuel return?
Old Jul 12, 2006 | 10:00 AM
BrianlG35C's Avatar
Ohio G Club Member
If I could do it all over again, I would of either kept the whp down to 360whp or added forged pistons/rods at the same time of my TT install. You'll be fine with SGP's recommendations.
Old Jul 12, 2006 | 01:46 PM
Dr_jitsu's Avatar
Ivory<
Greddy has a vested interest in telling you that all you need is their pre-tune. They will not be responsible when your engine blows. A good tune is 400 dollars....Good luck.
Old Jul 12, 2006 | 02:41 PM
  #30
Gman2004's Avatar
I already have the test pipes....and yes, I have to get gauges...I need boost...what else?
boost, a/f wideband, and water temp (OEM gauge is a POS and won't budge until your car is 220 degrees). EGT's are old school and not as important because of a/f widebands. In the old days they used to tune of EGT's.
