Greddy TT on Rev-Up w/ stock internals
Old Jul 11, 2006 | 09:53 AM
Dr_jitsu's Avatar
Mark at SGP is talking me into running the Greddy TT unit on my car (2006 coupe 6mt). I told him my goal is 350-360 rwp w/ maximum safety and reliability. His suggestion is to use the Greddy TT w/ low boost (6 lbs) wich will keep things safe for my stock internals. This set up, he claims is really the best over over SC and ST.
He is correct that this set up is probably the best in terms of reacing my HP and safety goals. The only problem is the cost. If he can do it w/ the HKS F-con IS (a brand new engine management system, much better than the Gredyy EU and half the price of the V-pro) for 8K I will definately go for it.
Of course it will probably be more that that.
Any opinions?
Old Jul 11, 2006 | 11:44 AM
ttrank's Avatar
Grocery getter
Sounds like a good plan to me. The TT is great set-up. I would say go Vortech but the Greddy will have less lag and tons of room to grow if you decide.
Old Jul 11, 2006 | 03:21 PM
philogene's Avatar
mos high
The rev up engine works real nice with the greddyTT. At 6lbs I did 378 and 7lbs 412.stock no exhuast at that time.
Old Jul 11, 2006 | 03:43 PM
Dr_jitsu's Avatar
Mark has quoted my a price of 8.7K for EVERYTHING out the door...w/ HKS V-pro IS installation and tune...fuel pump, BOV etc..... I am going for it!
PHILO: so, you did absolutely NO internal work?
I hear that the Rev-up has stronger internals anyway.
Old Jul 11, 2006 | 05:03 PM
philogene's Avatar
mos high
No work done at all.The kit tune , blowoff, fuel pump,and gauges run me 10K flate
Old Jul 11, 2006 | 05:53 PM
Dr_jitsu's Avatar
Philo: What engine management are you running, and should I get gauges?
Old Jul 11, 2006 | 06:11 PM
escobar929's Avatar
def get gauges, nexus autometer are the best looking and matches well w/ the interior of the car
Old Jul 11, 2006 | 06:14 PM
escobar929's Avatar
you should also get a clutch and a fuel return
Old Jul 11, 2006 | 06:21 PM
Dr_jitsu's Avatar
Never mind...it looks now, like when all is said and done I will be paying 10 K...I knew 8.7 was too good to be true.
Old Jul 11, 2006 | 06:22 PM
KenK2's Avatar
The Pole
^ +1.. Forgot about that Doc..
Old Jul 11, 2006 | 06:39 PM
Gman2004's Avatar
more like $15K for a complete TT install with gauges, clutch, exhaust, test pipes, etc. Chit adds up quick!
Old Jul 11, 2006 | 09:32 PM
Dr_jitsu's Avatar
I already have the test pipes....and yes, I have to get gauges...I need boost...what else?
Old Jul 11, 2006 | 09:54 PM
GZire's Avatar
Go for it all man since they've got your car apart.
Minimum IMHO:
Boost, wideband AFR, EGT
Supplemental:
Oil pressure, oil temp, fuel pressure, etc......
Old Jul 11, 2006 | 10:00 PM
KenK2's Avatar
The Pole
LOL.. Doc.. your gonna be at 15k before all is said and done......
Old Jul 11, 2006 | 10:06 PM
atar350's Avatar
You should stay pretty close to 10K, and I cant wait to see your numbers! Going TT is def worth the cash, especially if you arent going to be selling your car anytime soon, I know I am not going to be selling at all, Ill just get another car, and another, and another haha...
I recomend the Defi Gauges, but these things are expensive!
