Larger Blower Upgrade For Stillen On It's Way?
Old Aug 18, 2006 | 07:37 AM
  #31
superchargedg's Avatar
its actually pretty easy to install the stage 4.just rewire the new fmu to the old wires,color to color,replace the pulley,the fuel pump and the hardest part the 7th injector.on the coupe you need tiny fingers to start the longer screws that hold the injector retainer.it took me about 2 hours,with most of that time doing the 7th injector.
Old Aug 18, 2006 | 10:06 AM
  #32
mokc's Avatar
Yeah...Stillen won't touch anything that is not CARB legal. They won't even change out the pulley if you wanted to go stage III. I thought about doing it myself, but I know the fuel pump requires some mods to it and I would also need to change out the O-ring as well. Just not confident enough to do it. But here in CA, just about everyone goes to Stillen to do their stg II install, so i can't find anyone who is familiar enough with the kit to do the stg IV. I thought about going to GT Motorsports or maybe VRT. Anyone have any recommendations?
Old Aug 18, 2006 | 12:21 PM
  #33
Toptoneone's Avatar
Originally Posted by mokc
Who is doing your install for you?
gt motorsports in Rancho Cucamonga. Firast time dealing with them. They come highly recomended.
Old Aug 18, 2006 | 12:52 PM
  #34
mokc's Avatar
Very cool!! Thanks!! Please let us know how your install goes, because I'll probably be next in line!!
Old Aug 18, 2006 | 02:05 PM
  #35
ttrank's Avatar
Grocery getter
The mod to the fuel pump is just taking off a few tabs. It's simple.
If that is your concern have Stillen change the pump, that would not change the CARB. It's an easy change if you have a couple hours.
Old Aug 18, 2006 | 03:30 PM
  #36
mokc's Avatar
The walbro 255 at least for the coupe has to have some modifications to it inorder to get it fit. None the less, I tried asking Stillen ...asked to just put in the fuel pump, change the ss box, and injector and leave the stgII pulley. Technically will still be a stg II. The ss box only affects it at high rpm, so i am told, so i should be able to run it with a stg II pulley as long as i don't get a heavy foot, should just be very rich on the top end. I would change the pulley myself. But they wouldn't do that also. I finally just gave up and just looking else where to try to get a quality install.
Old Aug 18, 2006 | 04:04 PM
  #37
nate4598's Avatar
Have you try Miller Infiniti of Van Nuys?
Old Aug 18, 2006 | 05:36 PM
  #38
mokc's Avatar
No i haven't tried Miller Inifiniti, but i do recall that they screwed up your install, didn't they? Wasn't there some issues with your setup and you had to go back to Stillen to get them to correct the problems?
Old Aug 19, 2006 | 12:45 PM
  #39
nate4598's Avatar
As I was told, their techs were sent to Stillen to get more training after that screwed up
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Learned Hand
Oct 1, 2015 09:02 AM
