APS TT actuator upgrades?
Old Jul 18, 2006 | 09:34 PM
panda007's Avatar
Hi. Just got back from a dyno tune with Utec and GReddy Profec BC, however the tuner managed to pull out 391 rwhp on a built block (8.5 cp wiseco and GTM rods). I know it's a bit low... but it's still fun. However, I am really disappointed because of the cashflow onto the project. Numbers don't seem to add up? I want 500, dammit!
Tuner says the turbo actuators from APS are not providing higher boost. Right now, the car is running about 8 psi. I know Forge actuators are a great upgrade, but is it even necessary to hit 500 rwhp?
If it isn't, i'll seek another tuner... otherwise, it's time to add more money to the project.
thanks in advance.
panda.
Old Jul 18, 2006 | 09:39 PM
Julian's Avatar
thanks in advance.
panda.
You should be able to hit 12psi on the stock APS actuators.This should yeild about 450whp on a lower comprerssion bottom end with stock heads and cams.
MRC MOTORSPORTS LLC.
Home of the 673whp 560TQ beast from the East! @12 psi on 93 octane..More to come...
YOUR VQ35 SPECIALISTS AND #1 UTEC RETAILER AND TUNER IN THE COUNTRY!
WWW.RACEMRC.COM
732-251-8200
Sales@racemrc.com
AIM: SALESMRC
Old Jul 18, 2006 | 10:26 PM
James@APS's Avatar
Panda.
What exhaust are you running?
James
Old Jul 19, 2006 | 12:38 PM
panda007's Avatar
im running the HKS Ti TD exhaust.
Old Jul 19, 2006 | 02:23 PM
Julian's Avatar
I dont think exaust is the issue..Upgrade the actuators.
Old Jul 19, 2006 | 03:20 PM
bullitproof's Avatar
I agree. The forge actuators come with two springs, a 5-10 and a 10-15 when you wanna go crazy. IMO it's worth doing.
Old Jul 19, 2006 | 03:35 PM
panda007's Avatar
ok. so i guess it's settled: i might as well upgrade the actuators.
thanks guys. looks like i'll have to pay for more $$$ for dyno tune, labor and parts.
Old Jul 19, 2006 | 09:46 PM
James@APS's Avatar
How much boost do you want to run? If you run APS test pipes with a low back pressure exhaust system (APS true dual 2.5'' exhaust) you can easily run 12 psi from the base actuators. After that you will need to upgrade the base actuators.
James
Old Jul 20, 2006 | 04:27 PM
panda007's Avatar
i want to hit 500 rwhp. the HKS Ti dual is about 2.37" TD, which is not much of a difference to the smaller APS TD. I am also using test pipes as well.
thanks for the info though!
Old Jul 20, 2006 | 09:08 PM
James@APS's Avatar
You need to consider tube size and the muffler design, get either wrong and you will end up with high exhaust back pressure which definitely impacts on the amount of boost and power/torque possible from any given turbocharger.
James
KruZZe
Feb 27, 2023 05:04 PM
g.spot
May 9, 2016 10:54 PM
master111
Oct 6, 2015 01:36 AM
NyCrAzY
Oct 1, 2015 09:19 AM
