Turbo Cams for Revup (05' G35)
Old Jul 24, 2006 | 12:16 PM
g35_anonymous's Avatar
My engine is pulled and being built... I need to find cams ASAP. Are there cams available for the revup motor? Scott Performance, JWT, Tomei, Crower?
I understand that JWT will have them in a month or two but my motor will be back in my car and I will have gone through 3 sets of tires by then.
by the way, my build consists of:
Speed Force Racing TT kit (Tnetics 60-1)
Arias 8.6:1 pistons
Pauter rods
port/polish heads, radius valve cut, machine block
720cc inj/ walboro pump
SFR twin plenum Intake Manifold
HKS Ti Carbon 3" Exhaust
HKS SSQ BOV
Cometic headgasket
ARP headstud/mainstud kit
Profec e-01
SPA Technique Boost/EGT Oil Pressure/Water Temp Gauges
AEM Uego
Brembo Brake Kit 14" rotors 4 piston calipers
Technosqaure L-spec flash
hopefully cams!!!!!!!!!!!!!!!!!!!!!!! (may do the Ferrea Valve kit instead)
Top Secret Front Bumper
Top Secret Carbon Fiber Tail Light Covers
The car is currently under the knife and should be ready in 2-3 weeks... Thanks for the help...
Old Jul 24, 2006 | 04:18 PM
nevermind... Cams are not available yet for the revup.
Instead, I am going to do a koyo radiator, oil cooler, oil catch can and thermal coating...
with the power I will be making (600+whp without breaking a sweat ), cooling provisions makes more sense anyways.
Old Jul 24, 2006 | 10:30 PM
QuadCam's Avatar
you should proably add some sort fo engine managment to your list. A reflash isn't gonna cut it on your palnned setup.
UTEC
FCon Pro
Emanage Ultimate
many more too
Old Jul 24, 2006 | 11:28 PM
UTEC
FCon Pro
Emanage Ultimate
many more too
I'm running the Split Second EM... Waiting for AEM's stand alone to come out...
The reflash is just for top speed and redline (L-Spec).
Old Jul 26, 2006 | 01:25 AM
bullitproof's Avatar
I don't think AEM is gonna do a 350z system. There's a company that modified a universal kit to work with the 350 but it's not warrantied by AEM and i havent heard anything on the boards for a while. I would go utec or f-con.
Old Jul 26, 2006 | 11:35 AM
I won't hold my breath then.
thnx for the tip.
Old Jul 26, 2006 | 02:44 PM
badlittleboy007's Avatar
hey how much it costs you to build a motor?? thanks
Old Jul 27, 2006 | 12:31 AM
rookie's Avatar
Is this the first rev up with the SFR kit?
Old Jul 27, 2006 | 12:49 AM
Dr_jitsu's Avatar
Since your going all out, why don't you use the HKS F-Con VPro?
Old Jul 27, 2006 | 06:24 PM
or the utec? good question... I was under the impression that AEM's standalone was under development and would swap the SS with the new EMS upon availability. The SS comes with SFR's kit and is completely capable of providing the engine management I will need for my tune.
I may go with the HKS or utec or I may wait. I am still working some things out. Also, because of my aforementioned plan to wait on a stand-alone, I did not leave much room in my budget to get finicky on my EMS at this time. That is certainly a factor as well.
Old Jul 27, 2006 | 06:34 PM
I don't know what the bottom-end build cost was... Labor was factored in to the overall project and sponsorships came into play as well. I can tell you that I have spent close to $25K on everything (brakes, suspension, gauges, TT, Build, Labor, bodykit, Interior, etc...)
Old Jul 27, 2006 | 11:29 PM
Dr_jitsu's Avatar
In that case, why not get the best engine management to bring it all together
Old Aug 12, 2006 | 01:02 PM
AboostedG's Avatar
It's been a couple of weeks, What's your progress?? Anymore updates on JWT Cams or others?
Old Aug 12, 2006 | 09:39 PM
Sundeviljay's Avatar
i have a set of JWT cams...v1....want those? they won't work for your revup?
Old Aug 13, 2006 | 12:34 AM
EricIsKlumzyee's Avatar
intakes cams are avliable but exhaust cams arnt.. i think someone makes a set tho.. i'm not 100% sure i can find out for u if ur really interested.. other then that any cam shop can make the cams you want if u know the specs or if the place building ur motor can degree it for you
