Calling All G's With Aps St!
Old Aug 7, 2006 | 08:49 PM
trey.hutcheson's Avatar
I've only known one guy with the APS single, and he's had several problems. I believe he had issues with the wastegate springs at first, and not holding boost. Then something else happened and the blades on the turbine got all munged. Not sure on that issue.
I don't know about these issues in full detail, and if any of the fault lies with the engineering of the kit or the quality of the materials and/or craftsmanship. But I do know that I wouldn't purchase one myself.
Old Aug 7, 2006 | 08:58 PM
James@APS's Avatar
Not holding boost to redline is caused by the fitment of a very restrictive exhaust system............no fault of the turbo system.
James
Old Aug 8, 2006 | 02:48 AM
ttrank's Avatar
Grocery getter
I wanted to add this from the other thread:
Originally Posted by Zivman
Complete BS. I have personally installed both kits with my two hands and both are of equivalent quality. I agree it is an entry level FI system, but not in terms of quality or completeness, but because of mass air flow and price point vs their other offerings.
The install on the twins is SIGNIFICANTLY more complex and time consuming. The single should be installed EASILY in 10+ hrs less time than the twins. An example of something fairly time consuming on the twins that the single does not have are a lot of studs that need to be set in the engine block as well as the turbo housings. Also just consider mounting up two turbos in limited space vs one.
As far as discontinuing the kits, well, I hope you all do realize that at somepoint every kit APS or any other manufacturer puts out there will be discontinued. That said, I feel APS is trying to peak some interest in this somewhat overlooked setup. They might lure those on the fence into buying the kit by making it a bit more attractive.
For this price, the setup cannot be touched by anything out there. Bang for the buck exceeds any other offering APS has or any that of any other manufacturer IMHO.
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
