Finally got some dyno numbers!
Old Aug 7, 2006 | 03:57 PM
KPierson's Avatar
Well, I'm about 18 months in to my full build and I finally got the car street tuned and on a dyno. I was honestly expecting less power, but I'll take what I can get! Max WHP - 407, max tq - 373. This was done on Sunoco 94 octane fuel.
The car is a 2004 G35 coupe with a fully built bottom end and an APS TT. For more info on the car check out: http://www.kptechnologies.com/dynos/
Old Aug 7, 2006 | 05:01 PM
wa2good's Avatar
Nice numbers, very typical (depending on your built motors C/R) Well done.
Old Aug 7, 2006 | 05:05 PM
KPierson's Avatar
It's 8.6:1
Old Aug 7, 2006 | 05:13 PM
ttrank's Avatar
Grocery getter
Nice job. Looks like a great curve for a fun ride!
Old Aug 7, 2006 | 10:45 PM
GZire's Avatar
Congrats Kevin, I'm glad you got your car back. Did you change out the wastegate springs, or did you stay stock?
Old Aug 7, 2006 | 11:12 PM
KPierson's Avatar
I have an upgraded spring. I'm actually running the absolute lowest boost pressure possible right now as I get it tuned. I'll probably do the tuning in steps from here on out. I can't wait to get it done!
Old Aug 8, 2006 | 02:28 PM
GZire's Avatar
I see Kevin, best of luck.
Old Aug 8, 2006 | 03:10 PM
Serengettisandg's Avatar
Turn it up a bit once you have seated the rings. 8.6:1 and 7psi is not even close to pushing that thing on 94 octane. Hell I bet it will run fine like that on 89. I think you will find a nice balance of reliability and power at right around 12-14psi with pump gas. I am thinking with proper tuning and the right timing curve you can do 16psi with pump no problem.
Old Aug 8, 2006 | 03:29 PM
KPierson's Avatar
I've got at least 2000 miles on the new motor, so I would hope that my rings are seated by now. I'm actually going ot leave it just the way it is for every day driving, as I really like how slowly the torque comes on. I think the gradual torque increase will really improve the reliability of the motor.
But, of course with a flick of a switch I'll be able to turn on my boost controller and run 12-14psi of lag free power!!!!!
seagrasser
May 3, 2022 09:43 AM
Gwhut?
Sep 19, 2015 11:33 PM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
