Monitor Using Nav Screen
Old Sep 17, 2006 | 09:39 AM
GeorgtownG's Avatar
First, I wasn't sure how to search for this, so I'm just going to post and hopefully see some good results. I want to monitor air and fuel, maybe oil temp and some others that I haven't decided on yet. Why couldn't I use my nav screen to monitor all of this. Everyone is mounting gauges, well I don't want to add the gauges if I could use another media to see the outputs. I could always add a computer (mac) to the car, so why couldn't I monitor everything via pc. Is there a system already out there that is capable to do this? Hopefully, this makes sense to everyone.
Old Sep 18, 2006 | 02:46 AM
Drewer's Avatar
I think you used to be able to do this with the HKS CAMP system, but you still had to have an video input to the nav system. In order to make it work, you'd have to do something like: probe -> HKS CAMP -> avelectronics -> Nav screen. There might be better ways to do it now, since this was more than a year ago that I was looking into doing the same thing. The thoughts I've read/heard about it are that people want to have access to their monitoring at the same time as having the nav function available, so it just didn't turn out to be a popular idea. I don't know if I'd do it or not, since a zeitrionix guage can be stealthly mounted and provide you with a lot of necessary monitoring while at the same time you could still use your navigation. Good luck with whatever you end up doing!
-drew
Old Sep 18, 2006 | 02:49 AM
GurgenPB's Avatar
I have been doing it for a while....and it's a kick-*** system...truly unparalleled imo.
Check out the short video that i made.
http://www.gurgen.com/G35%20Videos/lm1_chunk_2.avi
make sure to right click and save... otherwise it only plays back the audio for some reason (if you try to stream).
EDIT: at the time, some inputs were not working...now they all do...and I also have knock indication as well.
Old Sep 18, 2006 | 08:08 AM
myG35ZX's Avatar
Outstanding. Can you give more deatails on the hardware required to do this? Also, what was needed to connect it to the Nav screen?
On a side note, Gurgen, do you have issues with traction? If you did, how did you deal with it?
Old Sep 18, 2006 | 09:46 AM
GeorgtownG's Avatar
Sweet,
I also would like to know what is needed to do this. Gurgen, hopefully this isn't a stupid question, but I didn't see anything in your signature. What FI system are you running?
Old Sep 18, 2006 | 12:33 PM
GurgenPB's Avatar
Hey Guys
Issues with traction i definitely do have...but not much, since i am running pretty low boost (9-10psi) due to lack of a good EM solution. So aside from having wide tires...not much else done there.
As far the setup...i have a aftermarket NAV screen, which has a descrete video in chaneel, which comes out of my laptop. To see the system, go to innovatemotorsports.com. It's a modular system. They makethe popular lc-1/xd-1 combo wideband kit. But ther eis a lot more to this. Look into their product line and the LogChain concept. For your reference, I have one of their LM-1's, LMA-2 ("rpm wire"), LC-1, and two AuxBoxes (LMA-3). Giving me 17 channels. I am looking to expand it further.... and they more coming in the next two months, I jsut can't say what exactly.
Old Sep 18, 2006 | 12:34 PM
GurgenPB's Avatar
Originally Posted by GeorgtownG
Sweet,
I am running a Power Enterprise Twin Turbo, built engine, fuel system and many many many more mods.
Old Sep 18, 2006 | 05:40 PM
myG35ZX's Avatar
Thanks Gurgen. I think I can use the stock screen with one of those navbox devices to display the monitoring. I'll check them out.
I want more power but keep going back and forth on the traction and $$$. At 42K miles on a 18 month old car, I have feeling my 100 mile daily commute would cause much wear and tear on any FI setup. But the 100 miles sure would be fun!
Old Sep 19, 2006 | 01:30 PM
GeorgtownG's Avatar
Yes, thanks again Gurgen, I'm already on my way to monitoring using my nav.
Old Sep 19, 2006 | 01:33 PM
GeorgtownG's Avatar
[QUOTE=myG35ZX]Thanks Gurgen. I think I can use the stock screen with one of those navbox devices to display the monitoring. I'll check them out.
myG35ZX,
Let me know what medium you use to work with your nav screen, I too am going this route.
Old Sep 19, 2006 | 07:54 PM
KPierson's Avatar
I just got my UTEC displaying on my Navi screen over the weekend.
I can view A/F, RPM, boost, knock, injector duty cycle, and a few other less important things that I can't remember right now. I would love to add fuel pressure and oil temp, but that probably won't ever happen.
I am using my laptop running through a Composite-->RGB converter. I have a 'special' switch that allows me to use the 'OK' button on my Navi to switch between OEM Navi and my laptop display. My 'special' switch also processes the 'OK' screen for me automatically!
Old Sep 19, 2006 | 10:40 PM
Skyline_G35's Avatar
English dude, English
I have the Stillen SC and the AVIC-N1 headunit with multiple inputs, audio and video. What do I need to get to show boost, a/f ratios and the such on my AVIC-N1?
Old Sep 19, 2006 | 10:45 PM
GurgenPB's Avatar
check out innovatemotorsports.com
Old Sep 19, 2006 | 10:51 PM
Thanks Gurgen. But is there anything else that is affordable? Like a couple hundred or something?
Old Sep 19, 2006 | 11:04 PM
KPierson's Avatar
The UTEC will do it as well (with help from a laptop) but you'll be looking at over a grand for everything.
