Monitor Using Nav Screen
Old Sep 20, 2006 | 07:02 PM
myG35ZX's Avatar
Originally Posted by KPierson
The UTEC will do it as well (with help from a laptop) but you'll be looking at over a grand for everything.
Will you make a kit for this? If not, how about a parts list?
Old Sep 20, 2006 | 09:23 PM
KPierson's Avatar
You don't need a kit, just the right parts that are already availilble.
1. Laptop with composite output
2. Composite -->RGB converter
3. UTEC
There are a ton of Composite to RGB converters availible on the market.
Old Sep 22, 2006 | 08:04 AM
myG35ZX's Avatar
Great! Thanks.
Old Sep 22, 2006 | 11:30 PM
KPierson's Avatar
https://g35driver.com/forums/forced-induction/117871-utec-oem-navi.html
More info on my setup, with 2 videos
Old Sep 22, 2006 | 11:54 PM
MechEE's Avatar
If the UTEC communication protocol is published, making a converter that read in the data stream and generated RGB video would not be very hard. This would bypass the need for a laptop. If I had a UTEC on my car, that's what I'd do.
I'm surprised that there aren't more generic sensor to RGB video units out there now that more and more cars are shipping with displays.
Old Sep 23, 2006 | 10:34 AM
KPierson's Avatar
It's not a difficult protocol (I would guess). It simply outputs ascii text that can be read directly by Hyperterminal. The software I'm using is third party and he figured it out.
Old Sep 23, 2006 | 07:10 PM
MechEE's Avatar
Well then, that should be cake! If you only want a couple colors (say, orange and black) on the screen, you could just bit-bang the RGB with your favorite micro.
Old Sep 24, 2006 | 12:12 PM
SI_G35Coupe's Avatar
Originally Posted by GurgenPB
check out innovatemotorsports.com
i tried to download your video but it only plays 13 seconds of silence for me without any kind of video. can you clarify something for me... what combination of Innovate products are you running?
i'm planning on FI in the near future, and basically what i'm looking for is something i can run thru my laptop to datalog and show me some type of virtual gauges on the navigation screen (with at least AF, EGT, boost). can LogWorks be set to display the virtual gauges in fullscreen?
i was looking at the Innovate LC-1 wideband and the LMA-3 AuxBox... would that cover everything i'm looking to do?
Old Sep 24, 2006 | 10:14 PM
GurgenPB's Avatar
did you right click and save to desktop and THEN only try to play. It's a weird encoding...won't stream.
I have an LM-1, LMA-2, LC-1, and TWO AuxBox's, and an XD-16 gauge... connected in that order. That's 17 usable channels.
The combination you mentioned wil get you a wideband plus 5 additional channesl. Research on their site the AuxBox...and download the AuxBox PDF manual and read it...you will learn alot from that alone, as well what the unit can do...it's versatile, extremely accurate, and race-level capability.
With the Auxbox, you can do EGT or CHT (you will need to get a separrate thermocouple (go to motorsportinnovations.com i belive...the link is on te innovate "tuner resources" section - 3rd party products) for EGT), RPM, Boost, accelerometer, or any of those individual channels can accept external 0-5v input channels, like from any of our sensors. Look here: http://www.innovatemotorsports.com/r...ecu_pinout.php for the g35 harness diagrams...i wrote that document myself.
HTH
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
Chauzilla
Sep 27, 2015 04:34 PM
G2B35AGN
Sep 25, 2015 10:49 PM
