vortech install help????
Old Sep 26, 2006 | 03:03 PM
bgsean42's Avatar
anyone in the socal area who can help with an install??? i already have the blower mounted piping mounted ic mounted as well as the ecu wired up.. I just need help with fmu as well as oil pan. i wound up taping the oil pan spacer and can't get the nozzle that came with the kit to get all the way in the 5/8 id tube runnninh fromt he blower which happends to be the drain line.. And having problems with mounting the fmu dont know where as well as which line of the 4 that run on the passenger side is the fuel line that i need to cut and tap into.. any help would be appreciated and i live in so cal so if there is anyone who is willing to drive down who has some experience withthe kit i would be willing to give some $$ if possible rather not put car on flat bed and have it toed all the way to gtmotorsports i would rather just drive it there if it is drivabnle thank sean
Old Sep 27, 2006 | 11:23 AM
denverinfiniti's Avatar
Do you have the instructions that came with the kit?? The FMU goes in the passenger side on the sub frame by the mounting bolt for the pass. lower control arm. As for which line to use for fuel, you dont need to cut anything. The kit comes with the lines that just plugged right into the stock system. The connection you need is on the pass. side back by the fall wall. Its covered by a blue or green(cant remember for sure) C-clip looking thing. Cant miss it.
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
gatorglaze
Sep 10, 2015 12:03 PM
n2fooz
Sep 4, 2015 07:46 PM
Machine Head
Sep 4, 2015 07:22 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
