Built.. SC.. Sedan
Old Oct 15, 2006 | 06:27 PM
sickg35s's Avatar
Built.. SC.. Sedan
Fully Built sedan
6MT swap
Vortech SC
9.5psi
and a lot of mods.
Hopefully get a smaller pulley soon for 13psi boost...
Attached Thumbnails Built.. SC.. Sedan-new-car-1.jpg   Built.. SC.. Sedan-new-car-002.jpg   Built.. SC.. Sedan-new-car-003.jpg   Built.. SC.. Sedan-new-car-004.jpg   Built.. SC.. Sedan-dyno-excellent.jpg
Old Oct 15, 2006 | 07:23 PM
rookie's Avatar
Dam man, you went all out. Looks super sleeper too. 1/4 mile tracking it on the 28th?
absolutg's Avatar
workin...
wow, sick. any reason you didn't go TT after building the engine? can you give us some details of the build? this is my plan when i get the car itch a few years down the road
Old Oct 15, 2006 | 08:23 PM
wa2good's Avatar
Originally Posted by sickg35s
Fully Built sedan
6MT swap
Vortech SC
9.5psi
and a lot of mods.
Nice Vortech work! What did your motor build consist of, parts, cams, port and polish heads, compression ratio, etc.? What size pulley are you going to try to use for 13psi.?
Old Oct 15, 2006 | 08:49 PM
sickg35s's Avatar
Wesco pistons
GTM rods
JWT cams
81
New fuel rails, injectors, fuel pump, and return.
Hopefully the 2.62 pulley if that will make 13psi. Probably more like 12psi.
Old Oct 16, 2006 | 12:36 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
That's awesome, you're one of the few FI sedans here.
-GP-
Old Oct 16, 2006 | 12:42 AM
codeflux's Avatar
6MT swap - wow. crazy G!
Old Oct 16, 2006 | 12:53 AM
Mr_pharmD's Avatar
its alittle lean up top 13s. Try to get SAE numbers from them but still really good numbers for only 9.5 psi.
Old Oct 16, 2006 | 12:55 AM
bullitproof's Avatar
Very nice!!!
Old Oct 16, 2006 | 08:24 AM
sickg35s's Avatar
Originally Posted by HomieG35
Can that SC make up in boost what you lose in compression? I know turbos can make up for the extra space with boost, but how much power do you make now and how much will it make on 13psi?
I was going to go with 8.5:1 comp also, but am trying to be talked out of it by the shop with my ProCharger.
There is a dyno posted. About 450whp at redline. At 13psi, and redline set to 7000rpm; I predict around 525-540whp depending on the tune. I really want to switch to a TT setup. Then my torque curve would be alomost 100wtq more than what it is now. Probably the JWT w/ the upgraded turbos.
Old Oct 16, 2006 | 08:26 AM
sickg35s's Avatar
Yeah I know. My injectors are running 120% at redline. If I want more boost I would have to switch the injectors. Really my motor is set at 6500rpm redline for safety reasons.
Old Oct 16, 2006 | 08:28 AM
sickg35s's Avatar
I want to track the car. Where are you going the 28th?
Old Oct 17, 2006 | 02:16 AM
ttrank's Avatar
Grocery getter
Sweet another FI sedan!
Great work.
Old Oct 17, 2006 | 06:43 AM
wa2good's Avatar
Sounds like a solid choice... Lemme know if/when you decide to go with our VRT/JWT 700BB kit.
