GT Motorsports Stroker Kit Upgrade...
Old Oct 19, 2006 | 10:54 PM
SAM@GTM's Avatar
We are in the process of redisigning our web site, so please bear with us. We will make our product introductions here in the meantime.
First…the GT Motorsports 3.78-4.24L Stroker Kits:
Stroke: 81.4-87.0-90.0mm (3.54-3.78-3.91L displacement with a 96mm bore, 3.84-4.10-4.24L with 100mm bore)
Bore: 96-100mm
Sleeves: Darton MID T-sleeves
We are pleased to introduce the absolute ultimate performance upgrade for the Nissan VQ35DE platform, the meticulously and thoroughly engineered stroker upgrade that brings the displacement of the VQ35DE to 4.26L (and optionally to 3.8L). The complete upgrade includes everything you need to take the VQ35 to an entirely new performance level. Achieving reliability that is required in street-driven cars at extreme performance levels is the true mark of complete and thorough design, and the primary design objective GT Motorsports set out to achieve.
Crankshaft:
Three version of the crankshaft are available, 81.4mm (stock stroke), 87mm, and 90mm strokes. Each crankshaft (cut from 4340 chromoly high-tensile steel alloy billet) is hardened and tempered for a target tensile range of at least 930-1080 MPa (135,000-157,000 psi). The alloy incorporates 0.40% of carbon, proven to provide the highest degree of tensile, compression, and sheering strengths. Additionally, the alloy provides the maximum resistance to high-magnitude vibrational and impact forces found at high engine revolutions. Rapid-rate changes in engine revolutions at very high output levels, especially if utilized with an engine management system capable of flat-shifts (anti-lag shifts), exert high sheer forces on crank journals. Hence, the GTM® 4340 chromoly steel crank is the only material capable of tolerating these conditions in a street engine, while still retaining a large safety margin and real long term reliability and longevity.
Pistons
Two piston types are available. The Arias/GTM Extreme Duty, and the Wiseco/GTM Extreme Duty. Both are from zero-silicon aluminum forging, and are designed to have the highest heat and deformation resistance. They utilize buttons instead of spring locks, providing additional support. These GTM pistons are the first to integrate a gas expansion groove between the two ring grooves, allowing additional small, yet critical, volume for gas expansion. The piston also incorporates a slightly taller than usual design, with longer skirts to minimize movement and vibration.
Rods
Designed in-house, and manufactured from the same 4340 billet chromoly steel. This material was chosen for this setup over titanium due to longevity, and over a regular forging due to the added strength. Each rod weights 500 grams, and is tested to withstand an equivalent of 2100ft-lb of torque on a 6cyl engine. This unique design allows for an unprecedented compression force/weight ratio, making it the most thoroughly designed and most suitable rod available for the VQ35DE.
The Block
We utilize the Darton® MID T-sleeves to round out the design. The sleeves are bored to 100mm bore. The block and heads are prepared to accept oversize ARP 2000-series 12mm studs, with the use of Timesert® steel thread inserts. Upon completion, each of the block’s cooling system is assembled, sealed with a torque plate, and it’s water jacket pressure tested to 30psi (stock cooling system pressure is defined by the radiator cap relief pressure which is 13-16psi) while dipped in a pressurized water chamber at 230deg F. This test is designed to simulate the expansion of the aluminum and the steel sleeves (which are a copper-based alloy designed to expand similar to Al) seen in normal operation, whilst verifying the proper seal of the sleeves against the block. Additionally, the block/sleeves are designed to retain the stock oil jets for proper piston cooling and bore lubrication.
The individual components are only part of the story. It’s the combination of the components and the flawless implementation that speaks to premium level quality of this upgrade. Several combinations and options are made available to suit every need.
Availability
Now
Turnaround time
6-8 weeks
Prices
Full upgrade: 3.78-4.24L - $8900 (includes assembly of the short block with Darton sleeves)
Parts only: Crank (any stroke)/Pistons/Rods - $5800/$5300 (Arias/Wiseco)
We’ll be here to answer any questions that anyone will have. Thanks.
Next… GTM Turbo Cams…
Attached Thumbnails GT Motorsports Stroker Kit Upgrade...-mvc-731x.jpg   GT Motorsports Stroker Kit Upgrade...-mvc-733x.jpg   GT Motorsports Stroker Kit Upgrade...-mvc-779x.jpg   GT Motorsports Stroker Kit Upgrade...-mvc-739x.jpg   GT Motorsports Stroker Kit Upgrade...-mvc-760x.jpg
Old Oct 19, 2006 | 10:56 PM
SAM@GTM's Avatar
More pictures
Pistons and rods
Attached Thumbnails GT Motorsports Stroker Kit Upgrade...-mvc-734x.jpg   GT Motorsports Stroker Kit Upgrade...-mvc-735x.jpg   GT Motorsports Stroker Kit Upgrade...-mvc-736x.jpg
Old Oct 19, 2006 | 10:57 PM
SAM@GTM's Avatar
More pictures
For more pictures/discussion, see this tread on my350z...
Old Oct 19, 2006 | 11:48 PM
martyg35's Avatar
Sweet ..More stuff to add to my wish list
Old Oct 20, 2006 | 01:54 AM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
looks good sam.
a bit too much dinero for me now.
thanks for the email. i will be calling you after SEMA in regards to my car.
Old Oct 20, 2006 | 04:23 PM
GReddySetGO's Avatar
Do the "part only" include sleeves?
Old Oct 21, 2006 | 08:28 PM
GurgenPB's Avatar
I believe no, it's just for the parts listed above, crank, rods, pistons
Old Oct 21, 2006 | 09:51 PM
mraturbo's Avatar
Nice...
Maybe premature yet you are saying they are available NOW!
Any News on Output and Performance?
Torque
WHP
Boost Levels
Fuel needs
Injectors Needed
Cooling Issues?
We are at Cal-speedway, right next to you again Sunday 10-23-06, bring your test car out and let's see how she runs.
Thanks and Good-luck!
M
Old Oct 21, 2006 | 10:39 PM
ttrank's Avatar
Grocery getter
I would love to see some more details on this kit.
Old Oct 25, 2006 | 09:16 PM
symalik's Avatar
goo GTM!
Old Oct 25, 2006 | 09:36 PM
mraturbo's Avatar
Originally Posted by bb319675
Hey Sam,
What other forums have you posted about your stroker kit besides here and my350z? You might want to let Michael(VRT) know so he can post this exact reply at those forums also.
Hey Sam, "Thanks and Good-luck!" oh, and " " too
Must be hard to be #1 when others just dig at you all the time.
Leonard
Despite what you might think, We could use a stroker set-up today and if you actually read my post, I am willing to buy the kit and test it. If it works well, I am sure we can sell many of them.
So Not Sure about your sarcasm! As for the invitation to the track, Sharif suggested I meet Sam. I was right down the street from them Saturday and Sunday and was hoping we could meet.
So Hope You Have a Nice Day.
M
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
bigmike
Sep 17, 2015 01:58 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
