Is it possible...
Old Oct 23, 2006 | 01:58 PM
TwilightBLUES's Avatar
Is it possible...
Is it possible to add a pulley to where the vortech blower runs seperate from the power steering etc.. Anyone attempt this????
Old Oct 31, 2006 | 01:00 PM
ISMSOLUTIONS's Avatar
I've actually looked into this. You would need a custom Crank Pulley that is double width to handle more than 1 belt, and the others would need to be spaced to accept the new location as well.
Not worth it as fa as I can tell with research.
I'd rather have a a full Cog pulley setup if anything...
Rick
Old Oct 31, 2006 | 02:44 PM
I guess it is a lot easier said than done. thanks for the input ISM
Old Oct 31, 2006 | 02:48 PM
yep - the whole issue becomes belt alignment...
For me, to go that far, I would do a compound pulley, 1/2 as cog for the blower direct, and let the factory belts run as normal...though you would figure Vortech would not have gone out of their way if there was a cheaper and easier solution to what they have already done.
Rick
Old Nov 1, 2006 | 10:30 AM
Q45tech's Avatar
One must balance the angular [sideways] forces that any accessory drive exerts on the crankshaft bearings and the balancer..........failure to do so will result in faster front main bearing wear not to mention oil leaks from front main seal.
Old Nov 1, 2006 | 10:45 AM
Texasscout's Avatar
Rick
Someone on here was working on a full "toothed" belt set-up. I don't remember who. However, I think it was for a Stillen SC.
Asumis51
Apr 14, 2015 06:37 PM
Adro
Sep 12, 2014 01:23 AM
vandium
Apr 2, 2014 07:16 PM
SFever
Nov 25, 2012 05:58 PM
