cheaper to go custom?
Old Nov 14, 2006 | 07:04 PM
G35ftw's Avatar
Does anyone here have a custom turbo setup on their G? I'm trying to find the cheapest way possible to go FI but at the same time I want a quality setup. As far as i know most turbo kits are over $6000 and I was thinking maybe I could save some money by getting the parts individually and putting a kit together myself.
Old Nov 14, 2006 | 08:29 PM
wongy's Avatar
you can get the APS ST for just under 5 i think
Old Nov 14, 2006 | 08:45 PM
Jeff92se's Avatar
Red Card Crew
I will assume if you are asking this question you are not an experienced mechanic.
If you aren't, then cheap + custom = two things:
a) Unfinished project
b) BOOM!
Old Nov 14, 2006 | 09:00 PM
filipm's Avatar
not to mention it will be hard to find all the piping that you need. do you have a pipe bender?
Old Nov 14, 2006 | 09:26 PM
zazaracing's Avatar
Team Transport Member
I think you need to come to an understanding with yourself.... FI and cheap cant be used in the same sentence unless youre saying " It's not cheap to go FI"
I can honestly say I was one of the few to have the G when it first came out and with 1500 miles in the first week I took it to a custom turbo shop local to me. With great hook ups and everything at wholesale or below it was still going to run 7k for a custom build. This isnt your mom and pops shop either they build a few cars for Fast and Furious and plenty of show cars in the scene now.
The lower cost solution is going supercharger or single tubro. S/C if you have half a brain you can install it yourself to save some money. Turbo.... unless you have a lift good luck at least 1k for install. Hope you find a way to get it done man its the greatest feeling once youre boosted.
Old Nov 14, 2006 | 10:32 PM
GreenGoblin's Avatar
The goblin resurrection
ya there are some things that you just dont wanna do and cheap out on the f/i
Old Nov 14, 2006 | 10:54 PM
minus500's Avatar
I disagree. I think that if you can weld and have some knowledge on fabrication, you can do it. A simple design would be use the stock mani's with a single turbo(ie turbonetics set-up). The most challenging part would be the cutting and welding of all the piping. If you don't have much time on your hands, don't do it. This would definitely be labor and time intensive. Just my $.02
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
TurTLe*
Sep 29, 2015 01:43 PM
