JWT vs APS
Old Nov 15, 2006 | 11:35 PM
JDM7672's Avatar
JWT vs APS
Quick question, out of the two turbo kits which one has less turbo lag cause i am having trouble deciding on which kit to get cause i heard there are less lag on the JWT compare to the APS but is there that much of a difference?
If i went with the JWT i was going to send the car out to forged internals but if i went with the APS i can get it install at a local shop dont know what to do? looking to spend about 15k. any comments would help. Thanks.
Old Nov 16, 2006 | 01:34 AM
ttrank's Avatar
Grocery getter
They will have close to the same lag.
$15k. I assume you plan to do a mild engine build at the same time?
Between the two the APS is a more complete kit but you can't go wrong with either. I don't believe the JWT comes with a fuel return system.
Old Nov 16, 2006 | 01:37 AM
bullitproof's Avatar
ask sharif. he will tell you the kit that will be right for you. if another shop tells you jwt and sharif tells you aps, you would go with the shop that is doing the install, right? trust in the shop that is doing the install.
11bEMT
May 27, 2022 03:13 PM
Video Share
Jan 31, 2017 04:00 PM
g.spot
May 9, 2016 10:54 PM
bigmike
Sep 17, 2015 01:58 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
