New Plans for the Voretch Coupe
Old Mar 21, 2007 | 11:31 AM
FastDontLie's Avatar
...we dont need roads...
So would i still connect the ss box to the fuel return system to control it. Also anybody know how hard it would be to install the fuel return system and injectors?
Old Mar 22, 2007 | 11:34 AM
Heres whats happening now. I have a Walbro 255, will then be self installing fuel return kit, 440cc injectors and 3.12 pulley while the ecu is being flashed at AAM then taking it to SGP so they can tune the SS Box.
Im pretty sure I will also be needing a smaller belt, anyone know the size of the belt that goes w/ the 3.12 pulley?
Old Mar 22, 2007 | 12:18 PM
sentry65's Avatar
I think a 93 inch belt is what you need for the 3.12
Old Apr 5, 2007 | 05:13 PM
imalazeeass's Avatar
yup, 93 inch
Old Apr 5, 2007 | 05:17 PM
I have always thought that the 2.87 pulley needed you to build your internals. After reading other post im confused on what i should get. I want to be right at 400 whp.
Old Apr 5, 2007 | 05:31 PM
sentry65's Avatar
internals are fine with the 2.87, but IMO you need to make sure you have your ducks in a row. You should have good cooling, good fuel setup, good tune, good fuel/higher octane, possibly water injection, and some gauges to monitor things, not to mention good maintenance
Old Apr 7, 2007 | 08:10 PM
Update:
I just ordered my 440cc injectors, plug an play clips, utec & 4-bar map sensor. Hopefully next week ill be ordering my pulley and fuel return system. Will keep everyone updated on how things are going.
Old Apr 8, 2007 | 06:21 AM
Dan_K's Avatar
Although, there is a chance that the Vortech FMU could stick and fail, I have never heard of one case of this happening. I have heard of fuel lines coming off, but so far the Vortech Supplied FMU has been rock solid.
A return fuel system with the 3.12 is overkill IMHO. Another option no one has mentioned is, you could get rid of the Vortech FMU and just run a Walboro alone without a fuel return system. The only problem with this is higher than normal fuel pressure at idle.
Old Apr 9, 2007 | 02:32 PM
Your right, it may be overkill but for the saftey ill sacrifice. Also another guy is going to be using my FMU and i also have a credit with the shop that im buying it from. I still feel that the 2.87 may be to much on stock internals. I really just want 400whp. Can they do a conservative tune with the 2.87 to get it at 400?
Old Apr 9, 2007 | 06:04 PM
Dan_K's Avatar
They could, but your going to be running super rich. If you have cats, they will burn out very fast, since you will have so much unburnt fuel coming out of your exhaust. I've seen a couple people hit around 395 whp with the 3.12. Some even claim over 400whp, but its all relative.
Old Apr 9, 2007 | 06:21 PM
Good cooling? as Intercooler, upgrade thermostat.....
Good tune- check
good fuel- use 93 octane
Water injection- not to sure how that works.
Gauges- check
Good maintenance- oil every 3K, spark plugs
Still debating on 2.87 pulley or 3.12.
Old Apr 17, 2007 | 02:00 PM
Update:
Just got in yesterday my UTEC and injectors. Still need pulley and fuel return. Now would the 2.87 and water/meth injection be to much HP for stock internals?
Old Apr 17, 2007 | 05:42 PM
Triji's Avatar
Very good question... I think I am about to find out.
I know Sentry65 is running the 2.87 on the stock block with success...
Old Apr 17, 2007 | 05:57 PM
Dan_K's Avatar
Sentry's car isn't a DD. I think he only drives it on weekends and has a constant mix of 100 octane in his tank. Do you know anyone that has a 2.87 stock block daily driver?
Old Apr 17, 2007 | 09:16 PM
  #30
Triji's Avatar
Nope, not off the top of my head... My car is however a daily driver. I am running the 3.12 pulley and hitting 8.5 psi daily. During the winter I would hit as high as 10.5 w/ the 3.12 actually.
I just ordered my meth / water inj kit today and am going with a AAM return fuel kit, 550 injectors, walbro, 2.87 pulley (or 2.9 non slip design)... Also most likely a Utec if I can find a decent Utec Tuner in my area.
I have 72,000 miles on my car and 30K on my current Vortech set up.
