Stillen S/C stage 3 install
Old Apr 22, 2007 | 05:15 AM
  #31
wa2good's Avatar
Originally Posted by Chrlesmd
Is your s/c coolant reservoir bottle stainless steel? Mine is black plastic. Wonder why the difference.
Originally Posted by ttramk
Hmm wonder why. When did you buy that kit? I got mine about a year ago.
Stillen is always trying to cut costs, so they changed the SC intercooler reservoir from an aluminum unit to a less expensive cast ABS type plastic. Haven't seen a problem with it though, it just looks a little cheesier.
Old Apr 22, 2007 | 06:52 AM
  #32
superchargedg's Avatar
Originally Posted by Tonys-G
OK I tightened the main belt and I think I got it I will know for sure tomorow when I go to start her up in the morning wether i truley did or not
I don't know wether or not the injen CAI is overly loud on this kit cause I have not point of reference but it sounds pretty damn good to me
I think I might loosen the top belt more since it looks like everyone is telling me it is too tight
the injen is the loudest out there cause i had it and it was way to loud for me.i put a jwt popcharger on and cut down the noise level to about half.
Old Apr 22, 2007 | 01:00 PM
  #33
Chrlesmd's Avatar
Yeah, I figure w/ the long tube on the Injen, it probably just resonates the sound.
Old Apr 22, 2007 | 01:02 PM
  #34
Chrlesmd's Avatar
Cost cutting .
Old Apr 22, 2007 | 02:45 PM
  #35
Tonys-G's Avatar
OK so last night I couldn't go to sleep after work so around midnight I had the front end up on jack stands and tightend the main belt, now I have not had it squeal once since, it has been warm all day, but i think I got it
Old Apr 22, 2007 | 03:20 PM
  #36
thats the belt that always gives me trouble and it figures that its the one you can only tighten from underneath.
Old Apr 23, 2007 | 05:21 PM
  #37
ttrank's Avatar
Grocery getter
I had an issue with that one when it was first replaced but after the next tightening it was fine. Very annoying but that is true with most belts.
Next time consider getting Goodyear Gatorback belts. I never even had to re-tighten the ones I put on my car with the TT.
Old Apr 24, 2007 | 03:13 AM
  #38
wa2good's Avatar
Tim, TT kits do not put a strain on the cars pulley system like the supercharger systems do, that is why most of the time (at one time or another) all the cars belts (OEM or not) will have some sort of issue when a SC is being used, and no belt issues realy at all when turboed.
Old May 8, 2008 | 08:53 PM
  #39
tylersphile's Avatar
I have this (exact) supercharger (thanks ttrank/Tim!)... I didn't install Stillen's 2nd main belt idler pully, and experienced no slippage with Nissan belts (for 9 months). I recently changed to the Gatorback belts and they slip quite often, dispite tightness. I'm going to bite the bullet and install Stillem's pully right now.
Old May 8, 2008 | 09:10 PM
  #40
ttrank's Avatar
Grocery getter
That sucks. What about going back to some standard NAPA/Gates belts?
Old May 8, 2008 | 10:22 PM
  #41
ttrank's Avatar
Grocery getter
I would put it back on. I know it can cause some noise from time to time but if you over tighten the belts you could have some bearing issues.
k67p67
Engine - Power Adders
Aug 29, 2015 08:19 PM
Team STILLEN
Aug 10, 2015 08:17 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
bickfordbft
Jul 20, 2015 07:57 PM
