Questions about supercharge/turbo
Old May 8, 2008 | 02:48 PM
jooshee's Avatar
I have a 5at g35, I have the money and want to make it fast, should i turbo or supercharge it? If I do, what else would I need to get to make it run better
Old May 8, 2008 | 02:54 PM
Hi-TechG35's Avatar
SeArch There 1324657673567 and counting threads on this.
Old May 8, 2008 | 03:01 PM
1SlowSedan's Avatar
6mt>5at
Old May 8, 2008 | 03:02 PM
Texasscout's Avatar
There is a lot of thinking that goes into that question. Do you REALLY have the money to make it go fast? Twin Turbo with a built motor will be 20K if you want to do it RIGHT. If you stay under 400 hp at the crank, you can save a lot.
It also depends on WHAT kind of power CURVE you are looking for.
Positive displacement SC (Stillen, others) will give you more low end torque than a centrifugal type (vortec, HKS, PROCharger, others), but will give you more on the top end. Do you want high speed runs or street fun?
TT can give you some of both. Gobs of power, with a little lag and not as much below 2500 rpm, but once you get the twins spooled up, look out.
Look in the FI section; read, read, read then read some more. Ask questions after you do your research. There are probably more guys running FI here than any other G sight. Check out My350Z.com also.
Old May 8, 2008 | 03:08 PM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
search please. if you think you got enough money saved up for the kit, just save about 3-4k more just incase you need to get little misc. parts here n there cause they add up. but the world of FI is expensive...once you join, theres no going back
Old May 8, 2008 | 03:38 PM
EricIsKlumzyee's Avatar
https://g35driver.com/forums/forced-induction/217994-vortec-vs-jwt-sc-vs-tt-owners-need-your-feedback.html
^ READ THAT
Old May 8, 2008 | 03:45 PM
Sportcoupe35's Avatar
Yeh tons of threads on this (I probably started some of them myself)
I've been running a Vortech Supercharger (stock kit out of the box with a custom tune) for 2 years now.
Yeh it adds up, after everything, I'd say I spent around $8k-$9k on the engine for the supercharger and miscellaneous.
There's a lot of threads regarding drivability and having forced induction for an every day driver or to go full out power. I chose my vortech due to engine reliability with the vortech since it is my daily driver.
Old May 8, 2008 | 03:49 PM
AGThing1227's Avatar
Originally Posted by Klumzyee
and this: http://my350z.com/forum/showthread.php?t=112693. Just type in the search box "Twin Turbo", "Supercharger", or anything else like that. Lets just put it this way. The cheapest you will spend is ~$5000. Remember to not just save up for the F/I kit. You will also need money for gauges, install, problems, and things like that. You will most likely want an exhaust too. Please do not just say "I want to go F/I" without knowing what you are getting yourself into. Good luck!
-AGThing1227
Old May 8, 2008 | 10:28 PM
silver g's Avatar
Check out the FI section at My350Z. It's very informative over there, and those guys have tested just about everything. But you better have some money and like somebody else said be prepared to spend over 20K if you want it done right. If you want a good shop check out GT Motorsports or Forged Performance.
Old May 8, 2008 | 11:53 PM
jooshee's Avatar
thanks for the help
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
