Going FI
Old May 8, 2007 | 11:38 AM
cipriopt's Avatar
Going FI
Next week i will be purchasing an APS TT tuner kit. This kit doesn't come with the fuel management.
So, can anyone tell me how much can i push this on a stock block, without damaging anything? And also, how much hp should i expect?
I'm planning on racing some dude with a 07 Dodge Charger RT10 with a 5,7 380bhp engine. Do i stand any chances?
I'm open to suggestions.
Old May 8, 2007 | 12:33 PM
alan21's Avatar
first you will need to purchase injectors and an engine mahagement system try searching
Old May 8, 2007 | 12:51 PM
ttrank's Avatar
Grocery getter
If you are going with a stock block I would get the full APS kit. The Tuner kit is more for people wanting to push a bit more out of it with larger injectors a complete fuel return kit, UTEC (or better), etc.
With a good EM you can go to 400whp/400wtq with no problems. An ultra safe tune is ~380ish.
As for the race, you will beat him no problem. I have a Greddy TT 405/399 and the last time I was at the drags I raced a 300C SRT (~420hp) and beat him by over half a second with a bad launch spinning through 1st and 2nd. Those LX platform cars are heavy.
Old May 8, 2007 | 12:52 PM
617G's Avatar
CFW (Carbon Fiber Whore)
uhhhh...unless you want your car to blow, I suggest an EMU such as Utec and a CJM Fuel return. And get a real tune. How do you plan to tune the car with no EMU?
Old May 8, 2007 | 01:04 PM
ttrank's Avatar
Grocery getter
It is always good to have but you can go without a return kit as long as you stay around 8psi or less. Much above that and you need one.
Old May 8, 2007 | 02:07 PM
gumpdriver's Avatar
Montgomery's Finest
Get some injectors, return fuel system, walbro fuel pump, and a Utec. And call it a day.
Old May 8, 2007 | 02:38 PM
cipriopt's Avatar
And how much would that be extra?
Old May 8, 2007 | 02:54 PM
imalazeeass's Avatar
only a couple G's
Old May 8, 2007 | 03:19 PM
617G's Avatar
the whole point of buying a tuner kit is so you can purchase your own EMU and fuel components, not so you can save money on the kit.
Fuel Return = 1k
Walbro = ~$120
Injectors = ~$500
Utec = ~$900
You should call a shop that's experienced with adding FI to the VQ.
www.forgedperformance.com
Old May 8, 2007 | 04:57 PM
ttrank's Avatar
Grocery getter
Fuel Return = 1k
Walbro = ~$120
Injectors = ~$500
Utec = ~$900
+1
If your goal is to do the kit on your stock block and cash is tight go with the complete APS kit that comes with injectors, a partial return kit and the Unichip. You still need to add the fuel pump.
Old May 8, 2007 | 09:32 PM
Xman's Avatar
You might also want to add a AAA membership in case you need a tow.
Old May 9, 2007 | 09:32 AM
617G's Avatar
Infiniti comes with roadside assitance I've used it more than a couple times, LOL.
Old May 9, 2007 | 12:33 PM
ttrank's Avatar
Grocery getter
How long is that good for? 60k?
Old May 9, 2007 | 12:42 PM
617G's Avatar
I believe it's lifetime as long as you own the vehicle. It's part of the "Ownership Experience." But, last time I used it I had < 60k.
http://www.infiniti.com/ownership/experience.html
I also have AAA though because I save %15 on Auto Insurance.
Old May 9, 2007 | 01:02 PM
ttrank's Avatar
Grocery getter
Wow, I need to read that paperwork!
I had a IC tube come off and needed to get a tow a little while back. It cost me $80 for a 4 mile drive!
