dual throttle body
Old May 15, 2007 | 01:44 PM
spacecowboy's Avatar
dual throttle body
apparently this is a bitch for them to supercharge... stillen said they're havin trouble figuring out a set up.... could be a while.
anyone know anything about possible turbos? and esp. for the 5spd auto
Old May 15, 2007 | 03:12 PM
ampm24's Avatar
I can see how twins would be a cool setup. Twins turbos, twin intercoolers, twin BOVs, twin intakes. Not sure about pressure equalization, but should be possible. I hope they figure something out, because twins are on my future drawing board for the G37. I can see how superchargers could be a more difficult setup. Roots should be ok though cause you could keep the same intake configuration if hood clearance isn't an issue. With a snail blower though, it will need to dump into a y pipe or something.
Old May 15, 2007 | 03:16 PM
b00stedjustin's Avatar
don't know anything about possible turbo setups but I'm sure they're in the works for the Z and the 07 G sedans. There are a couple of SP kits that were unveiled at the last Tokyo Auto Salon so I don't know what Stillen's problem is. The double tb always seems more complicated to deal with and I wish the z32 came with 1 opposed to two. A turbo setup would definitely be easier to create I would think for the new motor.
Old May 15, 2007 | 03:55 PM
viguera's Avatar
I talked to the guys at Vinny Ten's shop and they tell me that a nitrous setup would be difficult as well right now...
Looks like we're staying NA for the time being.
Old May 15, 2007 | 04:42 PM
ttrank's Avatar
Grocery getter
Funny because SFR just made a twin TB twin-turbo set-up for a Z that came with one.
Old May 15, 2007 | 04:59 PM
which was a sick freaking setup.
Old May 16, 2007 | 01:00 PM
any link to this? pics?
Old May 16, 2007 | 01:07 PM
forget it, found it myself.... holy crap
http://www.speedforceracing.com/
edit: i called them... not for 2-3 months, then we will have a twin turbo set up....
500 at the wheels on 91 octane and no engine work.... i can't wait
Old May 16, 2007 | 01:26 PM
ttrank's Avatar
Grocery getter
500whp is a recipe for a big boom. Even on the HR, I would never exceed 425-450whp, unless you have separate funds set aside for a motor build.
Old May 16, 2007 | 02:13 PM
viguera's Avatar
That's exactly what I was told by the Vinny Ten guys. The new lighter internals on the HR will probably not be able to handle that kind of power.
Then again, you could probably start swapping out parts but that's just gonna add to the cost of the whole thing.
Old May 16, 2007 | 02:23 PM
the internals aren't that much lighter, the turbos run at 10psi, and the stock block is rated up to 600 hp, so i've been told. i mean, they ran it (the 350z)up to 476 at the wheels with no engine mods. that's more than enough for me.
and as for engine parts, pistons and rods would prob cost about $2000, so if you're spending the money on the turbos, chances are you can afford to upgrade these too. cosworth makes them, so they are quality.
Old May 16, 2007 | 02:24 PM
ttrank's Avatar
Grocery getter
Yeah you can always build the motor with better pistons, rods, etc for way more power. That is next on my to-do list.
Old May 16, 2007 | 02:26 PM
if you can wait, brian crower will have a stroker kit for the engine sometime soon... prob push the displacement to about 4150 (4.1) no clue about hp gains though
Old May 16, 2007 | 03:18 PM
ttrank's Avatar
Grocery getter
I would assume you could use most of the parts from the existing 3.9 or 4.2 stroker kits.
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
Usman Ali
Oct 4, 2015 08:23 PM
NyCrAzY
Oct 1, 2015 09:19 AM
