My NEW FMIC mounted... PE TT MT Sedan
Jul 3, 2007 | 07:47 PM
Quote: the new fmic looks like a beast. you gonna be at the CH meet this week (keep in mind it's not at the same place this week). hope to see you and your car out there!
Thanks bro, I'll be there almost for certain. See you there.
Reply 0
Feb 18, 2009 | 09:26 PM
So GurgenPB, how did the FMIC work out for higher boost levels? Any before/after dynos?
Reply 0
Feb 18, 2009 | 11:39 PM
Here's a compressor map I found of the PE1420 Turbo that come with the PE kit
here's Gurgen plugging in the RPM
I haven't done the conversion but it does look right..
Here's the min CFM needed at 14psi and 18psi..
Code:
	NA/CFM	          14psi/CFM	   18psi
0	0
200	10.57581019	20.72858796	23.68981481
400	21.15162037	41.45717593	47.37962963
600	31.72743056	62.18576389	71.06944444
800	42.30324074	82.91435185	94.75925926
1000	52.87905093	103.6429398	118.4490741
1200	63.45486111	124.3715278	142.1388889
1400	74.0306713	145.1001157	165.8287037
1600	84.60648148	165.8287037	189.5185185
1800	95.18229167	186.5572917	213.2083333
2000	105.7581019	207.2858796	236.8981481
2200	116.333912	228.0144676	260.587963
2400	126.9097222	248.7430556	284.2777778
2600	137.4855324	269.4716435	307.9675926
2800	148.0613426	290.2002315	331.6574074
3000	158.6371528	310.9288194	355.3472222
3200	169.212963	331.6574074	379.037037
3400	179.7887731	352.3859954	402.7268519
3600	190.3645833	373.1145833	426.4166667
3800	200.9403935	393.8431713	450.1064815
4000	211.5162037	414.5717593	473.7962963
4200	222.0920139	435.3003472	497.4861111
4400	232.6678241	456.0289352	521.1759259
4600	243.2436343	476.7575231	544.8657407
4800	253.8194444	497.4861111	568.5555556
5000	264.3952546	518.2146991	592.2453704
5200	274.9710648	538.943287	615.9351852
5400	285.546875	559.671875	639.625
5600	296.1226852	580.400463	663.3148148
5800	306.6984954	601.1290509	687.0046296
6000	317.2743056	621.8576389	710.6944444
6200	327.8501157	642.5862269	734.3842593
6400	338.4259259	663.3148148	758.0740741
6600	349.0017361	684.0434028	781.7638889
6800	359.5775463	704.7719907	805.4537037
7000	370.1533565	725.5005787	829.1435185
I'll dig up and look at the number and conversion from CFM to M3/min since the compressor map is using m3/min. But just looking at Gurgen's plot at psi above 14psi the turbo is really almost past its efficiency area so not sure how much more you can cool it down if the turbo is almost at the edge. I'm pretty sure the bigger FMIC helped. I'm interested how much improvement Gurgen got.. lol I also bought his old FMIC which has been sitting in my closet for over a year!!!
I just looked at my CFM spreadsheet for our VQ Motor and a quick glance of the PE1420 compressor map. I'll dig deeper tomorrow once I get my good nite sleep.. lol
Reply 0
Feb 19, 2009 | 03:58 PM
Thanks for the data. I'm not used to those scales though - by chance do you have the flow lines for the VQ at the various RPMs on a pressure ratio vs mass air graph? If not, I'll do the conversion, but just checking...
Reply 0
Feb 19, 2009 | 04:28 PM
Quote: Thanks for the data. I'm not used to those scales though - by chance do you have the flow lines for the VQ at the various RPMs on a pressure ratio vs mass air graph? If not, I'll do the conversion, but just checking...
Never really care about Mass Air so all I have or at least I like to look at things using pressure. Majority of the compressor map are in pressure anyways.. If you want lbs/min then just multiply the CFM with .069 and you'll get the lbs/min.. I hope we are on the same page here... lol
Here's Lbs/min version..
Code:
RPM	NA/lbs	14psi	18psi
0	0	1.96	2.24
200	0.73	1.43	1.63
400	1.46	2.86	3.27
600	2.19	4.29	4.90
800	2.92	5.72	6.54
1000	3.65	7.15	8.17
1200	4.38	8.58	9.81
1400	5.11	10.01	11.44
1600	5.84	11.44	13.08
1800	6.57	12.87	14.71
2000	7.30	14.30	16.35
2200	8.03	15.73	17.98
2400	8.76	17.16	19.62
2600	9.49	18.59	21.25
2800	10.22	20.02	22.88
3000	10.95	21.45	24.52
3200	11.68	22.88	26.15
3400	12.41	24.31	27.79
3600	13.14	25.74	29.42
3800	13.86	27.18	31.06
4000	14.59	28.61	32.69
4200	15.32	30.04	34.33
4400	16.05	31.47	35.96
4600	16.78	32.90	37.60
4800	17.51	34.33	39.23
5000	18.24	35.76	40.86
5200	18.97	37.19	42.50
5400	19.70	38.62	44.13
5600	20.43	40.05	45.77
5800	21.16	41.48	47.40
6000	21.89	42.91	49.04
6200	22.62	44.34	50.67
6400	23.35	45.77	52.31
6600	24.08	47.20	53.94
6800	24.81	48.63	55.58
7000	25.54	50.06	57.21
Reply 0
Feb 19, 2009 | 10:54 PM
how does the plumbing work on that PE kit? the charge pipes Y together before the IC?
Interesting.
2.5" deep stock IC is smaller than the stock Vortech IC. I can imagine that thing prolly heat soaked at ~400 hp. The PE kits only make ~450 though right? ANd like stated above, woulda been interesting to get some before and after AIT's as those turbos are prolly pumping some hot air so far past their efficiency.
Reply 0
Feb 20, 2009 | 04:07 AM
Gurgen doesn't really frequent the forums much, can't really blame him, every time he trys to educate people they just harass him, oh well their loss.
Currently he is running the intercooler posted in this thread, with a custom Aquamist direct port water injection system being controlled by his MoTeC M800, he and I are the only ones with this setup (custom water injection), except he has me one up on the EMS. (I am controlling my water injection via the HFS-5)
I have no doubts his car will break 500rwhp on 91 octane, without methanol - just water. Currently his car is only road tuned so we don't know the numbers, also it is basically a track car now since he daily drives an A8 L (much easier on the kidneys ) so power delivery and boost response is more important to him than peak numbers.
Hope this answers your questions,
-George
GT Motorsports
Reply 0
Feb 20, 2009 | 08:30 AM
Thanks George. It's still a little bit unclear to me how to represent different IC efficiencies onto a compressor map, or if that's even possible. My sense is that increasing IC efficiency will effectively broaden compressor efficiency curves, but I don't like to make assumptions. I was hoping someone might be able to spoon feed me the answer, but I'm sure it'll come to me eventually. I like the way Gurgen datalogged his runs right onto the compressor map.
FI'd G, thanks a bunch for the data and charts!
Reply 0
Feb 20, 2009 | 08:39 AM
Quote: how does the plumbing work on that PE kit? the charge pipes Y together before the IC?
Interesting.
All depends on what you want, but looking at the graphs and the datalogged runs, it looks like those turbos are perfectly suited to the track for that engine, at their peak efficiency between 4k-6k rpms.
Reply 0
Feb 20, 2009 | 09:03 AM
Looking good!
Reply 0
Feb 20, 2009 | 10:26 AM
I got the compressor map from this thread http://my350z.com/forum/forced-induc...ilt-motor.html but I believe the OP (SQUILL) used a VE of 100% to map the the turbo. You can see that above 15psi and at redline of 7000rpm that the turbo is already past its efficiency. I dont use 100% VE, I prefer a much conservative 85% VE since it is really hard to hit 100%VE near redline. Maybe someone correct me if our motor indeed hit 100% VE in the upper rpm. I know it is easier to hit 100% VE with FI than NA but I have read somewhere that 100% at near redline is not an easy task even with FI..
If you follow my conservative 85% VE table then the PETT should still be within the compressor map even at 18psi, if you follow the 100% VE correction then the turbo is way past it's efficiency at 7000rpm.
Reply 0
Feb 20, 2009 | 11:19 AM
Nobody shopped that picture? wtf?
Reply 0
Feb 20, 2009 | 11:48 AM
Because it is Gurgen's thread and he's a well respected member of the community. Gurgen's is one of the most knowledgeable and helpful member in here and my350z.com... Very knowledgeable guy even though there are some haters out there..
Reply 0
Feb 20, 2009 | 12:56 PM
BTW, that is not Gurgen in the picture, that is my good friend Kevin. He and I mounted the intercooler for Gurgen originally.
He brought it down to test fit it, then we said fvck it lets just mount this puppy!
-George
GT Motorsports
Reply 0
Feb 20, 2009 | 01:07 PM
  #30
sick!
Reply 0
