My NEW FMIC mounted... PE TT MT Sedan
Old Feb 20, 2009 | 05:20 PM
  #31
GurgenPB's Avatar
Hey Gus
Thought I'd chime in. Thanks George, rcdash, athenG for the kind words. I have indeed been just sickened by the level of misinformation on the forums, I am speaking in general, mostly on the other board. I;ve also been very busy with work and other projects to work on the car extensively or spend time on the forums like I used to.
I do have the next couple of days off, and will chime in on some of the discussion on compressor efficiencies. Since the posts of Squill and my own from a couple of years back, I have devised a detailed spreadsheet that calculates and graphs compressor efficiencies much more precisely. In several words, my compressor efficiency for a 3.5 L engine on the PE 1420 turbo is PERFECT. The problem is not that, it's turbine AR that's mated to that compressor that introduces way more back pressure that I would want for even peakier number. Yes, not the compressor...that's half the story, but the turbine side of things is the culprit. Unfortunately, though turbine compressor maps do exist, they are largely unpublished and are difficult to interpret, even for many engineers. Hence, we are left to other devices, overall very difficult ot implement on a personal budget, and very complicated procedures to determining ideal turbine size. hence, we are largely relegated to trial and error in picking it. The turbine size will determine the spool characteristic of a setup...i.e. how well the efficiencies of the COMPRESSOR side are realized in a given load/rpm condition. My setup delivers very good midrange and acceptable, though not ideal, top end... So, I'll live with that, in short, as the alternative is a lot of money for extra 30 hp on the top end, with would make my setup ideal (at least as far as the "old" VQ35 allows).
Old Feb 20, 2009 | 07:58 PM
  #32
str8dum1's Avatar
Still curious as to what data led to conclusion that the new IC was the optimal size/solution. I've never seen any before and after AIT's and honestly would love to see that kinda data.
Old Feb 20, 2009 | 10:19 PM
  #33
rcdash's Avatar
Gurgen, any chance of you sharing that spreadsheet? I'd like to make one for the 700bb turbo. Does water injection have any impact on turbine efficiency by lowering EGTs? I would think it would be one of the few non-mechanical methods that would help...
Old Feb 21, 2009 | 01:11 AM
  #34
FI'ed G's Avatar
The JWT 700bb is using a GT28RS compressor wheel right?
Here are some numbers I have in my spreadsheet using the formula in Corky Bell's book to calculate airflow rate of an engine with and w/o a turbo, and I verified the number with a turbo calculator (http://www.squirrelpf.com/turbocalc/). The turbo calculator is more advance because you can specify a different VE on a different RPM range, you can also set the IAT.
Here's what I got using the formula but I only used a VE of 90% on the entire rpm range for simplicity purposes. I also didn't make adjustment base on the IAT and altitude so this is a rough estimate on how much airflow is needed on our engine. I only copied 10psi-20psi.
LOL I posted this at 1am EST and I just took a sleeping pill an hour ago so I'm half asleep now and have no idea if I'm making any sense... lol
Basic Airflow rate W/O turbo = (cidxrpmx.05xEv)/1728
Flow rate is in cfm and displacement is in cubic inches.
Ev= volumetric efficiency
.5= due to four stroke engine fill its cylinder only 1/2 of the time
1728 =convert cubic inches to cubic feet
Example: VQ cid = 215, rpm = 7000, Ev = 90%
Basic engine cfm = (215x7000x0.5x90)/1728 = 391.92 cfm
Airflow rate with turbo/SC = pressure ratio x basic engine cfm
let us use 2.37bar (20psi)
2.37x391.92 = 928.9cfm
lbs/min conversion = cfm * .069
928.9cfm x .069 = 64.1 lbs/min
In the end you want a turbo that can flow 64.1lbs/min or 928.9cfm at 7000rpm, since Gurgen has a TT then you can cut the flow in half because there are 2 turbo.
Code:
This is lbs/min
rpm	10psi	11psi	12psi	13psi	14psi	15psi	16psi	17psi	18psi	19psi	20psi
200	1.3	1.4	1.4	1.5	1.5	1.6	1.6	1.7	1.7	1.8	1.8
400	2.6	2.7	2.8	2.9	3.0	3.1	3.2	3.4	3.5	3.6	3.7
600	3.9	4.1	4.2	4.4	4.5	4.7	4.9	5.0	5.2	5.4	5.5
800	5.2	5.4	5.6	5.8	6.1	6.2	6.5	6.7	6.9	7.1	7.3
1000	6.5	6.8	7.0	7.3	7.6	7.8	8.1	8.4	8.7	8.9	9.2
1200	7.8	8.1	8.4	8.8	9.1	9.4	9.7	10.1	10.4	10.7	11.0
1400	9.1	9.5	9.8	10.2	10.6	10.9	11.4	11.7	12.1	12.5	12.8
1600	10.4	10.8	11.2	11.7	12.1	12.5	13.0	13.4	13.8	14.3	14.6
1800	11.7	12.2	12.7	13.1	13.6	14.0	14.6	15.1	15.6	16.1	16.5
2000	13.0	13.5	14.1	14.6	15.1	15.6	16.2	16.8	17.3	17.8	18.3
2200	14.3	14.9	15.5	16.1	16.7	17.2	17.8	18.4	19.0	19.6	20.1
2400	15.6	16.2	16.9	17.5	18.2	18.7	19.5	20.1	20.8	21.4	22.0
2600	16.9	17.6	18.3	19.0	19.7	20.3	21.1	21.8	22.5	23.2	23.8
2800	18.2	18.9	19.7	20.4	21.2	21.9	22.7	23.5	24.2	25.0	25.6
3000	19.5	20.3	21.1	21.9	22.7	23.4	24.3	25.1	26.0	26.8	27.5
3200	20.8	21.6	22.5	23.4	24.2	25.0	26.0	26.8	27.7	28.6	29.3
3400	22.1	23.0	23.9	24.8	25.7	26.5	27.6	28.5	29.4	30.3	31.1
3600	23.4	24.3	25.3	26.3	27.3	28.1	29.2	30.2	31.2	32.1	33.0
3800	24.7	25.7	26.7	27.7	28.8	29.7	30.8	31.9	32.9	33.9	34.8
4000	26.0	27.0	28.1	29.2	30.3	31.2	32.5	33.5	34.6	35.7	36.6
4200	27.3	28.4	29.5	30.7	31.8	32.8	34.1	35.2	36.3	37.5	38.5
4400	28.6	29.7	30.9	32.1	33.3	34.3	35.7	36.9	38.1	39.3	40.3
4600	29.9	31.1	32.3	33.6	34.8	35.9	37.3	38.6	39.8	41.1	42.1
4800	31.2	32.5	33.7	35.0	36.3	37.5	38.9	40.2	41.5	42.8	43.9
5000	32.5	33.8	35.2	36.5	37.9	39.0	40.6	41.9	43.3	44.6	45.8
5200	33.7	35.2	36.6	38.0	39.4	40.6	42.2	43.6	45.0	46.4	47.6
5400	35.0	36.5	38.0	39.4	40.9	42.1	43.8	45.3	46.7	48.2	49.4
5600	36.3	37.9	39.4	40.9	42.4	43.7	45.4	46.9	48.5	50.0	51.3
5800	37.6	39.2	40.8	42.3	43.9	45.3	47.1	48.6	50.2	51.8	53.1
6000	38.9	40.6	42.2	43.8	45.4	46.8	48.7	50.3	51.9	53.5	54.9
6200	40.2	41.9	43.6	45.3	46.9	48.4	50.3	52.0	53.7	55.3	56.8
6400	41.5	43.3	45.0	46.7	48.5	49.9	51.9	53.7	55.4	57.1	58.6
6600	42.8	44.6	46.4	48.2	50.0	51.5	53.5	55.3	57.1	58.9	60.4
6800	44.1	46.0	47.8	49.7	51.5	53.1	55.2	57.0	58.8	60.7	62.3
7000	45.4	47.3	49.2	51.1	53.0	54.6	53.6	55.4	57.2	59.0	64.1
Here are 2 maps I got from the turbo calculator website. I set the full boost to hit at 4100rpm on this graph.
18psi
20psi
Maybe Gurgen has a better or more accurate calculation..
Old Feb 23, 2009 | 12:56 PM
  #35
rcdash's Avatar
Thanks for that - very interesting - need some time to work through it but looks spot on at first glance.
One thing I don't understand is why my power drops off after 6500 rpm, but by looking at the way you mapped it out, the turbos are moving into higher efficiency at higher rpm. Hmmm... Maybe my cams are just closing the intake valves too soon? (JWT S2)
Old Feb 23, 2009 | 02:40 PM
  #36
FI'ed G's Avatar
/\ isn't that most VQ has this problem unless you upgrade your plenum to a Cosworth or something that breath better on the higher rpm?
Old Feb 23, 2009 | 03:57 PM
  #37
rcdash's Avatar
Quick question, what value did you use for BSFC to get the graph above?
Old Feb 23, 2009 | 04:22 PM
  #38
FI'ed G's Avatar
shoot, I forgot to change that coz I was already half asleep so I just took the default value (0.43). I had to play around with a different hp # to get the desired PSI I want though...
Old Feb 23, 2009 | 07:01 PM
  #39
rcdash's Avatar
Yep I think .43 is way too efficient. What I don't understand is that you can keep lowering the A/F ratio and it moves the line around. Hmmm....
Old Feb 23, 2009 | 07:21 PM
  #40
FI'ed G's Avatar
Originally Posted by Jtrain
And how everyone is suddenly and expert on it.
You dont have to post here if you dont have anything to contribute
Are you talking about the boost line? If you dont change the Target HP and if you lean out the A/F then it will take less boost to achieve the target HP but you are right coz I set the target A/f to 9.0:1 and the boost line went down even further It should be loosing power at that A/F..
Old Feb 24, 2009 | 12:40 AM
  #41
rcdash's Avatar
Hmmm... I also thought power would increase until you reach stoich. ratio of 14.7 with the excess generally used to cool the charge (with more required for FI vs NA).
Old Mar 21, 2009 | 02:54 AM
  #42
G2FAST's Avatar
Gurgen, car is looking amazing, that IC is a monster bro looking great. I will say the knowledge and time Gurgen has invested in his car is amazing and really elevates the knowledge that we all should understand our vq's. I always look forward to hearing from Gurgen and his reason and study behind his decisions made on his car.
Jusseth
Sep 13, 2020 12:25 PM
yosip1115
Forced Induction
Jan 28, 2016 02:51 PM
TheKnite
Aug 14, 2015 07:59 PM
chinee
Aug 8, 2015 10:11 AM
teamghost
Jul 28, 2015 04:52 PM
