Need some help on Vortech
Old Jul 18, 2007 | 11:19 AM
falcon50driver's Avatar
Had some issues with the Vortech over the past 1 1/2 months. First the piggy-back controller was bad, and although Vortech sent a replacement fast, it still kept my car OTS for a week. After 2 weeks of driving the car I noticed I wasn't getting more than 5 lbs. of boost at 6000rpm.I made some adjustments to the BOV but it didn't help.Then the S/C went south.I shipped the unit back to Vortech, and they said there was major damage to the bearings and gearing due to a defect in the bearings.I received the unit back yesterday and reinstalled it, adjusted the BOV according to Vortech spec's, looking forward to getting the car back on the road after 5 weeks, and NO BOOST! maybe 1 lb. I checked for airleaks and didn't find any. Anyone have any ideas
Old Jul 18, 2007 | 11:41 AM
Deang35c6's Avatar
Either you have a boost leak from the piping or the BOV is defective. You can hear the BOV close at WOT. It goes from a constant hiss to quiet as you boost. What sounds do you hear at WOT? Good luck
Old Jul 18, 2007 | 09:17 PM
booger's Avatar
6 or 7 threads showing on the adjustment bolt on the BOV . Check your vacuum lines for cuts ,tears and holes . Make sure the serp belt is plenty tight
seagrasser
May 3, 2022 09:43 AM
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
n2fooz
Sep 4, 2015 07:46 PM
