Oil Pan removal question
Old Jul 31, 2007 | 02:55 PM
Drewer's Avatar
For those that have done it before, did you follow the service manual's recommendation to use a seal cutter? I haven't had any luck finding this tool at any of the auto parts stores I've looked. . .I'll try home depot next. I guess I wonder if it's really necessary? I'm thinking yes since it specifically calls out not to use a flathead screwdriver. What have you guys done? Just chance it?
Here's the tool:
Old Jul 31, 2007 | 02:57 PM
JdM_G35's Avatar
i just carefully pryed mine.
Old Jul 31, 2007 | 02:59 PM
Voodoo's Avatar
CCT-we call down the rain
I've used a flat metal 3" putty knife. Worked just fine, also used it to clean off the remaining gasket on the pan and block.
Old Jul 31, 2007 | 03:02 PM
JdM_G35's Avatar
i used a razor blade to clean up all that silicon
Old Jul 31, 2007 | 03:06 PM
Drewer's Avatar
Sweet. Thanks guys! I've had a gasket scraper lying around for years, so it'll finally get put to use. I think I'll get a putty knife too and do a combo "pull gently" and attack it with the putty knife.
-andrew
Old Jul 31, 2007 | 03:08 PM
FastDontLie's Avatar
...we dont need roads...
Yup, just use the putty knife to get it loose. Then just carefully pry it off. Its just a tight fit under the car. Good luck!!
Old Dec 31, 2008 | 05:15 PM
Knowledge35's Avatar
what happens if you use a oil pan gasket from an auto part store? or do you only use the ones from the dealer?
Old Dec 31, 2008 | 05:58 PM
str8dum1's Avatar
there's no pre-made oil pan gasket. You use Ultra Grey sealant in a tube to put it back together.
Old Dec 31, 2008 | 06:46 PM
clifftrail's Avatar
I don't know about that, I bought two from autozone when I got a 1" spacer. Worked and fit fine.
Old Jan 1, 2009 | 09:13 AM
superchargedg's Avatar
Yes there are and NAPA sells them.
Old Jan 4, 2009 | 03:45 AM
bythabay's Avatar
so by using one of these gaskets, no sealant needs to be used??
Old Jan 4, 2009 | 03:53 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
correct.... NO sealant if you use a gasket. If you put sealant on, and a gasket, it's like double gasketing and it WILL more than likely cause a leak.
-GP-
Old Jan 7, 2009 | 07:31 PM
QuadCam's Avatar
here it is. $7.99:
Old Jan 8, 2009 | 12:44 AM
str8dum1's Avatar
^^thats pretty nice then. will have to remember that next time i pull my pan.
Old Jan 8, 2009 | 01:16 AM
Scrooge's Avatar
I would use the razor blade to cut the seal around the oil pan and then use a thick guage putty knife to slowly start prying around the oil pan. After that I would use the gasket scraper and remove all the RTV. Last I would prep the surface by wipe both seal areas with brake cleaner (Make sure you use the brake cleaner that leaves no residue) to remove and film of oil and to have a nice surface to adhere to.
Also if you use Permatex Ultra grey. You have 5 minutes to have surface together and you have to wait 24 hrs for the RTV to cure. After that, put in the oil and filter and start the car and check for leaks.
