Compression checking
Old Jul 31, 2007 | 03:16 PM
Drewer's Avatar
Howdy again. Next on the agenda is to check my compression, so I'm going to do a compression check for giggles. . .well mostly to see if I'm on the verge of blowing my engine apart before I get the vortech installed. Has anyone done it themselves? Since the coil packs are so far from the spark plugs, I assume you have to use some sort of long neck gauge? Anyone recommend any products in particular? Thanks in advance!
-andrew
Old Jul 31, 2007 | 03:22 PM
Jeff92se's Avatar
Red Card Crew
-andrew
1) Good idea.
2) Yes or an extension
3) Most would work. I have one with a flex rubber hose with a steel extension. Analog type guage. Basicly one that's been in use for decades probably.
I suppose finding one with the extension built in would be best.
Old Jul 31, 2007 | 03:27 PM
MixturePinoy's Avatar
cute. you guys working together
what's a compression test? should I do it for any reason??
Old Jul 31, 2007 | 03:28 PM
Drewer's Avatar
Originally Posted by Jeff92se
1) Good idea.
Napa has a ton of them, so I'll check to see if they have one with a built in extension. Thx Jeff!
Old Jul 31, 2007 | 03:30 PM
Drewer's Avatar
Please tell me you didn't just ask that?!
"What's a battle?"
Old Jul 31, 2007 | 03:32 PM
Jeff92se's Avatar
Red Card Crew
#1. check my sig
#2. check what you just wrote
Basicly you stick your thingie into a hole and note the results on Drewer's face.
Old Jul 31, 2007 | 03:34 PM
Jeff92se's Avatar
Red Card Crew
Also read the manual for the proper procedure. ie.. TB open or closed, cranking time etc.. cold or warm.
You might want to make a note on how long the extension needs to be. If it's too short, UBscrewed. If it's too long, then it might hit stuff in the engine bay
Old Jul 31, 2007 | 03:36 PM
Drewer's Avatar
Yes, the expression on my face when cylinder 6 is 135psi.
On topic guys. . .on topic.
cpmiller22
Oct 10, 2018 10:54 AM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
invincible514
V36 Engine, Exhaust, Drivetrain & FI
Sep 15, 2015 05:06 PM
BigNiniPanini13
Sep 15, 2015 05:55 AM
