Beginning Stages of the ATI procharger on my 04 coupe 5AT!!
Old Oct 27, 2007 | 04:30 PM
  #31
KPierson's Avatar
You will only be able to see the very top of the radiator, and be prepared to burn yourself on it a time or two before you get used to it. For some reason, it just doesn't process when you see it that it is blazing hot.
Its a very tight fit in the G, since (unless they've changed things) it is designed for a Z. When installing the new radiator you will be able to move the A/C lines that run up the drivers side of the stock radiator. Once they are moved, you will have more room for the supercharger and less chance of the compressor running a hole through the A/C lines. My Procharger left a slight mark on my stock A/C lines from it moving around a bit.
Old Oct 28, 2007 | 12:55 AM
  #32
g35man04's Avatar
CLUB MODERATOR
yeah thats what i heard....im in the process of hoping to run a custom pipe and install a filter on it so i dont bring in so much dirt into the procharger.
Old Oct 29, 2007 | 11:53 PM
  #33
g35man04's Avatar
CLUB MODERATOR
little bit of an update...
Old Oct 30, 2007 | 12:40 AM
  #34
waijai's Avatar
i.love.gold
Man, I can't believe you had the piping welded to your ARC intake. You should have sold that thing to recoupe some money. And just used normal piping up to your throttle body.
Old Oct 30, 2007 | 03:17 AM
  #35
zazaracing's Avatar
Team Transport Member
dude i hope you tested the before welding it... I dont think its going to clear and if it does the blower is going to rattle against that like a tambourine.
I love the way it looks and been lookin into it myself but not the route I would have gone
Old Oct 30, 2007 | 07:36 AM
  #36
g35man04's Avatar
CLUB MODERATOR
pm sent.
Old Oct 30, 2007 | 07:38 AM
  #37
g35man04's Avatar
CLUB MODERATOR
clear what? Let me know what your talking about?? it clears the supercharger i know that. the only spot its touching is the strut bar..the problem im having is that the throttle body spacer i put on move the piping forward and up..i need to pull it off so that i have more room to work with and so it clears the Strut tower bar. other than that everything is clearing right now as far as the supercharger goes.
Old Oct 30, 2007 | 08:42 AM
  #38
JusG35c's Avatar
Where did you get te engine cover from?
Old Oct 30, 2007 | 09:17 AM
  #39
g35man04's Avatar
CLUB MODERATOR
somebody off the forum was selling so i picked it up.
Old Oct 30, 2007 | 09:38 AM
  #40
JusG35c's Avatar
Thanks for the reply. Good luck with the build.
Old Oct 30, 2007 | 06:09 PM
  #41
zazaracing's Avatar
in the pic it doesnt look like it was clearing the charger... also you hood come pretty close to it if im not mistake...
Looks b!tchen man I want to do the setup vortech has gives your a little more room to plat but the way the supercharger outlet is its kind of pain. I hate this 1 sided intercooler
Old Oct 30, 2007 | 07:28 PM
  #42
g35man04's Avatar
CLUB MODERATOR
yeah we will find out when i pick it up...it now wont be until thursday because they have to tune it then...
Old Nov 4, 2007 | 01:28 PM
  #43
gteclipse3's Avatar
any updates ??
Old Nov 4, 2007 | 04:25 PM
  #44
g35man04's Avatar
CLUB MODERATOR
ITS complete!!! i will get some vids up soon. I picked it up 2 days ago and everything is running good!
Old Nov 4, 2007 | 08:05 PM
  #45
waijai's Avatar
i.love.gold
Tuned? Fast? details man, details!
