Stillen SC + NOS
Old Nov 20, 2007 | 06:43 PM
FiveSeven SS190's Avatar
Stillen SC + NOS
Has anyone tried this yet?
Three things come to my mind:
(1) Is there a problem with "cold" shocking the twin screw rotors from the NOS?
(2) Fuel Distribution even through a supercharger (which is already adding fuel in the form of wet injection before supercharger via 7th injector)?
(3) Coating on rotors? Effect of NOS/FUEL? (I guess fuel is okay seeing how 7th inector is already putting fuel on twin screws)... though at SEMA I asked Eaton and they said that they would be afraid of fuel eating or wearing away the seal/spray that they coat the twin screw rotors with before installation and "pre-spin" unit to make a perfect seal...)
I was thinking of adding a 50 shot wet Nos on top of the Stillen Supercharger but was not sure if fuel will distribute correctly with a supercharger sitting on top.
I have done 50-70 Wet nos shot on other vehicles that are Turbo or NA but have never had a supercharger before.
I know WET NOS is generally okay for distribution within limited small HP injection application. I am not looking for big power via NOS, just a little boost for kicks!
What are your guys' thoughts and input?
Old Nov 20, 2007 | 09:36 PM
Audible Mayhem's Avatar
do it!! if you are in the south east US , bring it to me and i will do it..
i would like to do it with a utec though so we can add fuel using the injectors.
thanks!!
Old Nov 20, 2007 | 10:01 PM
weslutes's Avatar
I had a 55 shot on a stage three kit for about a year. It worked awesome for a while. Started burning a ton of oil, then dyno'd with 300whp. I knew something was wrong, so I pulled the motor for a build. The pistons literally fell out of the block. The rings were sooo toast.
Old Nov 21, 2007 | 07:38 AM
that is all cause of your tune. we have many many turbo and nitrous or supercharger and nitrous cars that are running strong.
a 55 shot of nitrous is a lot of power to add without even fuel distribution, i am sure it would fry the rings due to the amount of heat it would see.
if you do it with a utec, you can add fuel using the injectors so its evenly distributed....
Old Nov 21, 2007 | 02:25 PM
What about for timing? I remember about 1.5 Degrees of retard per 50 HP shot of NOS was the rule. How are you guys moving the timing on a G back 1.5 degrees?
Old Nov 21, 2007 | 02:38 PM
617G's Avatar
CFW (Carbon Fiber Whore)
not sure what you mean by how, but pretty much all EMU's can retard timing
Old Nov 24, 2007 | 01:32 AM
Nforce1's Avatar
That would be awesome... I'd really worry about reliability though
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
hawaiian5
Sep 20, 2015 07:12 PM
