ATI Procharger question
Old Dec 3, 2007 | 01:01 PM
mrimage's Avatar
i am planning on doing the utech with a walbro 255 and 440 injectors and a 8psi pulley. do i need a return system? i want to be reliable.How much whp you guys think i can make?
Old Dec 3, 2007 | 01:04 PM
Hi-TechG35's Avatar
Any forced induction system can be made reliable with a decent tune from a reputable tuner. With the ATI you should be somewhere around 350hp.
Old Dec 3, 2007 | 07:38 PM
sahtt57's Avatar
ATI is considered the more reliable choice [against Vortech for instance]. You do not 'need' an oil return system nor do you need to tap the oil pan, which is one benefit to the ATI system vs some competitors. Here's more info on the ATI g35 ati procharger and indeed you can expect about 100whp with the 8psi pulley reliably.
Old Dec 3, 2007 | 07:39 PM
Xblackg35X's Avatar
im only pushing 335whpi got the walbro 440injectors and utec with stock pulley.and by the way isnt it a 9psi pulley?
Old Dec 3, 2007 | 07:40 PM
Xblackg35X's Avatar
that was also after my car was warmed up. about 6 runs
Old Dec 3, 2007 | 08:14 PM
SDGeneralCounsel's Avatar
sounds like whomever tuned your car didn't know what he was doing
Old Dec 3, 2007 | 10:05 PM
mrimage's Avatar
i am talking about the return fuel system, and by the way 335 whp? the person who tune your car didn't do a good job, u need a new tuner. the stock fuel system from ati with the digital fmu give you more than 335 whp, the utech suppose to give you way more than that, being that it can fine tune
Old Dec 3, 2007 | 10:09 PM
mrimage's Avatar
you can order any psi pulley from ati i already have the part # for 8psi and 9psi pulley
Old Dec 3, 2007 | 10:44 PM
Xblackg35X's Avatar
i didnt know they made an 8psi pulley. mark at sgp raceing tuned it for me in houston
Old Dec 3, 2007 | 10:49 PM
mrimage's Avatar
well u need a new tuner, with the utech u can get way more power than that. i spoke with julian from mrc in nj and he told me that with the 8 psi pulley i can get 380whp
Old Dec 3, 2007 | 10:51 PM
mrimage's Avatar
guys if you have a stock 6psi pulley, just remember that, if you flash your car and remove the inline filter and use a setup filter through the radiator support, you can easily get up to 8psi without changing any pulley. the flash make your car rev higher, so the supercharger spool faster
Old Dec 4, 2007 | 12:23 AM
flashing is not a permanent fix. There are pleanty of threads on the forum with people complaining about zero gains or the ECU dumbing down the performance due to the reflash.
