My sedan turbo setup
Old Dec 6, 2007 | 09:56 AM
SouthernG35's Avatar
OK guys I think I have everything in order for my turbo install, I just wanted to see what you guys thought of the set up before I begin. My car is a 04 sedan 6mt. First off I have the turbo, intercooler and piping from a used Turbonetics kit (from a 350Z mt). I will be using a Precision Turbo SN-61 turbo in place of the old Turbonetics. It will bolt right in the place of the Turbonetics turbo. I have a slightly used SSV zwith thermol gasket, Walbro 255 fuel pump, 550cc RC injectors, tial 38mm wastegate, ac relocation lines, UTEC and map sensor (already installed), installing custom 2 ½” exhaust (no cats) to a first gen Stillen rear section. I will be running an Autometer Sport Compact series wideband a/f and boost gauge. I will probably install and oil temp and oil pressure gauge later. All this will be installed and tuned at a respected local shop here in my area. The guy installing it is just finishing up a friend of mine 2003 350Z right now. It is a custom kit that resembles the PowerLab. It should be done in the next couple of weeks. I will post his final numbers and pics of his setup when it is complete. Once his is finished my Sedan will go under the knife. Wish me luck.
Anyway guys do you see anything I am missing? Any other suggestions that I might need to think about. I would have loved to have Jeremy @ PF install the kit but Orlando is just no doable right know.
Thanks
Old Dec 6, 2007 | 09:58 AM
Hi-TechG35's Avatar
You forgot the fuel pump!
Old Dec 6, 2007 | 09:59 AM
Got it Walbro 255 sorry.
Old Dec 6, 2007 | 10:11 AM
Hi-TechG35's Avatar
Sounds like you're all set. Don't forget to get tuned too!
Old Dec 6, 2007 | 10:20 AM
Audible Mayhem's Avatar
good luck man!! sorry you couldnt make it down here...
Old Dec 6, 2007 | 12:48 PM
98intrigue's Avatar
I'm glad more and more sedans are taking the plunge. Looks like you have a promising setup.
If you decide not to do your intake setup like the 350Z, where you have to cut into your radiator support to put the filter behind the grill, let me know! I'll buy it!
Old Dec 10, 2007 | 07:23 PM
ttrank's Avatar
Grocery getter
Congrats!
It is very nice to see more boosted sedans!
There is room to cut for the 350Z style intake but you will need to bend some A/C lines and get the TN A/C line.
I cut the same kind of spot to do my intakes:
Old Dec 10, 2007 | 08:09 PM
O HELLA OEM's Avatar
looks sick!
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
LuisGee
Forced Induction
13
Jul 22, 2015 09:15 PM
Chattzx
Jul 17, 2015 11:23 AM
