View Poll Results: Which other gauge(s) would you pick?
Water temp
14
29.17%
Oil temp
18
37.50%
Voltage
12.50%
I don't care!
20.83%
Voters: 48. You may not vote on this poll
Which other gauge and why?
I'm installing a set of Autometer Nexus gauges.
I have decided to sell my Zeitronix which I like a lot but have always wanted the look of more gauges.
I currently have EGT, A/F Oil press, Fuel press and boost. I need a 6th and maybe 7th to complete my install.
Which one would you get?
Why?
Why?
Oil temp. For water temp you can use an OBD II display to read directly from the ECU.
Besides, oil temp is a more accurate reflection of the current engine temp, in my opinion.
As a note, I have autometer Oil Temp, Oil Press, and Boost in a 3 gauge A-Pillar pod, and a wideband and fuel press as part of my double DIN set up. I also have an Blitz R-Vit, which displays any OBDII readings; I have it displaying water temp, intake temp and battery voltage, normally.
The G does not have stock oil press or oil temp.
I voted "I dont car", not because I dont care, but because I have bo idea what gauge would be of more benefit to you. How do you like the Autometer? I'm trying to decide what gauges I want to get.
These are 52mm and I am doing 3 on the A pillar and 3 in a custom pod above the HVAC controls. It will look like the one G352NV did a while back.
https://g35driver.com/forums/attachm...5&d=1168040252
(the one above the navi screen)
Nice, I have a A-pillar gauge pod also, but I don't want too use it when the time finally comes.
I only like that custom pod better, if you don't mind me asking, about how much would that cost w/o paint??
You mean to make you one of the center ones? I'm not sure yet, I need to make mine first and see.
