Question on TT on rev up motor?
Old Feb 9, 2008 | 04:29 PM
n3ilG35c's Avatar
Anyone in G35driver have any trouble with Twin Turbo kit for the rev up motor? I been hearing stuff like the fuel problems. Im plannin to get the greddy TT kit end of this month and i have a rev up motor
p.s
I need Help plz help me!!!!
Old Feb 9, 2008 | 07:28 PM
str8dum1's Avatar
a good tuner will make sure you dont have any problems.
you'd only have fuel problems if you are pushing high horsepower.
Old Feb 9, 2008 | 07:48 PM
n3ilG35c's Avatar
thank you for the info i have one question I see alot of people on this forum use UTEC managment why?
Old Feb 9, 2008 | 10:27 PM
str8dum1's Avatar
realistically, you want to use the EMS that your tuner is most familiar with. Guys in the SE have forged and performance factory as the 2 big tuners and they both know UTEC. They also use the Fcon also but the UTEC is much cheaper. Hal Tech is among the best as you can control cam timing and more with that but is expensive and there arent many tuners that work with it.
Old Feb 13, 2008 | 01:09 PM
rcdash's Avatar
The problem with the rev-ups is oil consumption and I've never read a good explanation for why it happens.
The UTEC is popular because it operates as a stand-alone EMS at load and is relatively cheap compared to other stand-alone offerings. It is still the best bang for the buck under $1000 for tuning, especially if you do not live next to a UpRev authorized tuner (in which case I would favor Osiris for about the same money).
Old Feb 13, 2008 | 04:02 PM
QuadCam's Avatar
no issues with my TT revup.
Old Feb 13, 2008 | 04:39 PM
Cpt. Picard's Avatar
Okay, I know how noobish this sounds but how do you know if you have rev-up and non rev-up motor?
Old Feb 14, 2008 | 02:03 AM
nutt's Avatar
isnt it 05 and up models?
Old Feb 14, 2008 | 10:26 AM
Audible Mayhem's Avatar
look on the front timing cover for blue and green plugs, those are revups.
also, it will say REV on your dash while driving...
if you are in the southeast US, give us a call. we have many many twin turbo revups, including the first US HKS twin turbo revup...
Old Feb 24, 2008 | 10:50 PM
BadBoy06's Avatar
basically smaller rings = more gunk build up= burning oil
Old Feb 24, 2008 | 11:52 PM
TTg35sedan's Avatar
The one thing i would say is if you are going to leave the motor stock and just add the turbo, check and make sure you are not burning oil first if you are take it to the dealer they have a procedure to document it and they will put a new long block in it. there is a tsb for it now
Old Feb 25, 2008 | 08:29 AM
rcdash's Avatar
They changed the piston rings in the revups? So building the motor (new pistons) would solve the issue then?
Old Feb 25, 2008 | 09:22 AM
QuadCam's Avatar
the rings aren't smaller.
Nissan changed the second compression ring on the revups. the new ring has a different edge profile and they also tightened the 2nd ring gap.
Old Feb 25, 2008 | 09:24 AM
QuadCam's Avatar
sure would. the block pistons, rods, and crank are the same. the only real differences in the stock short block are the 2nd rings, rod bolts, oil pump, and a small plate around the oil pump pickup.
Old Feb 25, 2008 | 12:58 PM
TTg35sedan's Avatar
yes building the motor would solve the issue. my buddy works at a infinity dealer by me and the only reason its burning oil is the rings. i have a 06 sedan that had the same problem at 3000 miles i pulled the motor built it from top to bottom and tt and no oil loss.
