Going TT soon, keep HFC's or go with TP?
Originally Posted by gte959s
How do you pass emissions? Do you switch out the test pipes for the emissions test?
Originally Posted by shdowflare
Yeah originally I was planning to do the JWT 530BB set but someone said I should just get the 700BB and have it boost controlled so it's safe for my stock G engine. So the HFC's are probably good for now. If I do go with the 700BB kit, and want to push past 450rwhp I guess I'd need to build my engine. Either way it sounds like I can keep the HFC until I decide to build up my engine to take full advantage of the 700BB kit (like you!)....
Good luck...
May be having a change of direction here...just ordered some quotes for a built motor + the JWT 700BB kit. Shooting for ~550rwhp. I've heard any more power than that and the car is not very streetable...any comments?
Built motor and 700BB, go with 3" downpipes and no cats.
550whp is a lot for the street.
is 550whp the right number for me?
Originally Posted by App6MT
550 is probably perfect for the street. Pick up a set of Toyo R888's and you'll be golden.
So I'd have thinner tires in the rear and thicker in the front...is this really what I want? Or are there racing tires that will have same dimensions as my OEM's?
with that much power you're going to want to buy bigger wheels and tires, that much power will require that much more traction. unless you enjoy making the rear come loose as much as i do
maybe I should rethink this then...I want to keep the OEM rims. Should I decrease the power output so I'm not spinning all the time?
Here is a question for you....have you ever driven a car with 500-RWHP before? Especially one with lack of traction?
Unless you invest in some d@mn good tires.
The good think about turbo's is you can turn the boost down when you don't need it...but on a 500+whp G/Z with JWT 700BB turbo's....the lowest you may be able to set the wastegate is around 450whp....unless you change the spring which may affect you at high boost....but that would lower the boost even more.
Have you ever driven in a twin turbo Porsche (which has less than 420 whp) .....2006 to 2008? ...well the 500 whp G/Z is way faster....not off the line (because of lack of traction and the TT Porsche is 4wd) but from a roll....Porsche cant hang. I have proven it many times.
Come to ZdayZ in May...I think the 16th if that's a Thursday......there will be tons of over 500, 600, 650, 700+ whp G/Z's there...and they will be happy to give you a demonstration. We are renting out an Airport to do top speed runs. From what I am told ...Nissan Magazine will be there to take pictures of the event for the magazine.
500 whp is a lot of for someone who is not experienced with it. Remember...that's over 600 HP.
There is nothing worst than flooring the pedal at 60 mph and finding the car trying to go sideways.... I am running over 600whp (over 700 HP) so it happens to me once in a while.
Originally Posted by XKR
You making me nervous with those kind of questions.
I don't think I'll be able to make it to Z day but I'm heading to a local DC meet this Sunday and will check out some of the rides there for sure!
Thanks again,
B
Thanks for all the info man. I'm pretty new to the FI game...I love the look of the OEM 19's (which I just bought!), so I wanted to run those for awhile. Do you think I'd be able to run the 700BB kit at ~450rwhp on the OEM 19 wheels/tires? I'm not opposed to getting better tires, providing they'll fit the OEM rims...
Thanks again,
B
Thanks again,
B
Thanks again,
B
Thanks again,
B
Yes you will be able to with good tires. Remember......to run the car at anything over 400whp...you will need to build the motor. 400 and under...you can run the stock motor.
