Thinking about doing a custom turbo install
Old Apr 18, 2008 | 02:51 PM
  #31
G35er4life's Avatar
Originally Posted by Jeff92se
N I T R O U S
I have a complete nitrous kit from my DSM so I could easily convert it to work on the G35 but I don't want nitrous. It's not what I am looking for and how is that any safer for my car? It's not, unless I run a 25hp shot. It will still require tuning, maybe even more tuning, since only for a short period of time I have to worry about excessive ****, where with the turbo it's a constant adjustment that needs to be made.
Old Apr 18, 2008 | 03:03 PM
  #32
Jeff92se's Avatar
Red Card Crew
How is it any less safe? And it's multi-thousands less to install. For only 50hp, I'd either run nitrous or full bolt ons + reflash
Old Apr 18, 2008 | 03:24 PM
  #33
CHudson Coupe's Avatar
If you are doing this because you want a turbo, that is absolutely fine and completely your choice. The only downside I see is that installing a turbo custom turbo system that will only give you 50hp will probably still end up costing close to a retail kit in the end, if done right.
My advice is to by a used Turbonetics kit (they sell all the time for like $3000, check out my350Z classifieds). This way, the cost is low, you get something you know is safe (as long as the parts are in good condition), you do get more power than you originally wanted but no one says you have to use all that power.
I think this route will be the same price-wise, give you more power that you can choose to use or not to use, and you will also have access to other people's FAQ's and troubleshooting problems with the kit. Something that is priceless a few years down the road, and you can also call up TN and they would give you help even though you bought it used. I'm only using TN as an example, all of the kits have there ups and downs, but for the least amount of money, and since you don't want a lot of power (>500), TN seems like a reasonable choice.
Old Apr 19, 2008 | 12:13 AM
  #34
Aced16's Avatar
i second nitrous! you can get away with a 50shot without a tune, but I WOULDNT RECOMMEND IT! 50hp turbokit is really not cost effective, but thats just my opinion.
Here is what i would so:
Full bpu's (intake, headers, tp's, exhaust, plenum spacer, reflash to correct A/F, and a small shot of nitrous since you already have the kit) that would be MORE then enough to keep up and outperform ALOT of cars, while still paying less then a custom kit that is done right, just my 2 cents though, GL!
Old Mar 2, 2009 | 02:09 PM
  #35
tiguy99's Avatar
Just curious...how much are we talking here and how safe is this for daily driving?
What kind of maintenance is required to keep up not only the vehicle itself but also the nitrous system as well?
Old Mar 3, 2009 | 07:26 PM
  #36
350Z T's Avatar
If you are capable, can weld and fabricate then you can do your own custom kit. That is what I did:
http://my350z.com/forum/forced-induc...brication.html
With a UTEC and Tuner it cost me about $2600. I used quality new parts (garret turbo, tial wastegate...ect). So if you do some shopping around you can probably put a good kit together for around $2k.
I ended up buying a Haltech, and that drove my budget waaay up but it's something I was ok with. I am hoping to dyno as soon as this dam snow melts.
Old Mar 4, 2009 | 12:48 PM
  #37
escobar929's Avatar
you dont really need a UTEC, there are a couple of people running boost w/ osiris.
just look for an osiris tuner and you'll be ok
i would recommend getting a kit like the turbonetics, that you can find for dirt cheap (2.5k-3k) and running a boost controller to bout 6psi, 3psi is just a waste of money IMO
Gookiecrunch
Aug 19, 2015 12:00 PM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
LuisGee
Forced Induction
13
Jul 22, 2015 09:15 PM
Chattzx
Jul 17, 2015 11:23 AM
