Turbonectic problem...
Old Apr 25, 2008 | 04:58 AM
G35pm's Avatar
Highly doubt the ECU. Vacuum leak? Leaks period? Do you have gauges? What do they read when you're at idle?
The reflash is rich by nature. Near redline, the car is super rich.
Join my350z.com and search. Problems like this with the TN kit have been beat to death. Probably a bad install.
Old Apr 27, 2008 | 01:37 PM
tommy2go's Avatar
The BOV is the raptor from turbonetic
I'm gonna clean the throttle body and get you guys the update :O)
Oh btw with those with turbonetic, ever feel like you want more power?
Old Apr 27, 2008 | 04:32 PM
G37Rider92649's Avatar
any updates
Old Apr 27, 2008 | 04:36 PM
Down_Shift's Avatar
Check the MAF sensor and the Plenum for leaks.. Did you reuse the same gaskets?
If you wanted more power, you bought the wrong kit lol.
I recommend you check out my350z for better help on mechanical stuff.
Old Apr 27, 2008 | 06:28 PM
hey man who installed your turbonetics?
Old Apr 27, 2008 | 06:30 PM
SDGeneralCounsel's Avatar
Originally Posted by Black Guy
We use turbo xs utecs and deatsch werks 600cc injectors on our turbonetics set ups.
Overkill much? You can only run injectors that size with because you tune the fuel delivery with a Utec
Old Apr 27, 2008 | 06:32 PM
haha, I think he people who go for the turbonetics kit end up going tt or for a larger turbo. You can always gut the kit and upgrade everything yourself. I know SFR has upgrade packages for the TN kit guys.
Old May 19, 2008 | 01:20 AM
tommy2go's Avatar
sorry guys
well I guess we found out that one of the spark plug has alot of oil (#6). Not sure at this point but we need to seal or replace one of the metal cyclinder. Its kinda confusing its one of the piece that surround the spark plug. Other than that I think I might consider rebuilding the bottom end of my motor. Let me know what you guys think.
BTW thanks for all you guys imput greatly appreciate
Old May 19, 2008 | 01:22 AM
tommy2go's Avatar
I also heard there is a stage 2 for the TN. If I want to push around 12 pounds in my car what should I do? I know I can upgrade the pistons and rods but is there another way?
Old May 20, 2008 | 03:22 PM
MIAPLAYA's Avatar
You have to be very careful on the stock rods as they are not up to too much boost. The car can be tuned to run safely at 10 PSI or more but you need to dial every thing exactly to make it work ook.
Old May 20, 2008 | 03:44 PM
Deathmage's Avatar
hmm.. you should get a custom tune with a utec. i think it's EMS related.
Old May 20, 2008 | 05:20 PM
sorry guys
Ummm, usually if you find a wet spark plug you have a blown injector. That is the easiest tell-tell if you think one of your cylinders is not firing.
Old May 20, 2008 | 05:25 PM
636Racer's Avatar
check your vacuum lines. also double check the manifold bolts. best way is to use carburator cleaner - spray it in any suspected areas and diagnose it that way. then double check the intercooler couplings. I doubt it's an electrical thing.
Old May 21, 2008 | 03:55 AM
tommy2go's Avatar
Me and my friend
Old May 21, 2008 | 03:57 AM
  #30
tommy2go's Avatar
what you usually gap the spark plug?
