Turbonectic problem...
Old Apr 24, 2008 | 05:44 AM
tommy2go's Avatar
So I have this kit on for about 2 months. Everytime it idles the car dips lower than 1k rmp and then it dies usually city driving. I checked all the hoses to see if it secure but have no idea what would do that. Is it because of ECU? hopefully someone can shine some light on this
Old Apr 24, 2008 | 08:42 AM
App6MT's Avatar
Littering and...
What sizes are your injectors? What EMS are you using?
I would post this on my350z.
Old Apr 24, 2008 | 10:05 AM
BAD430BENZ's Avatar
what year is your car ?.....a/t or 6 speed ?
Old Apr 24, 2008 | 10:18 AM
Hi-TechG35's Avatar
Also what are you using for a fuel pump and spark plugs?
Old Apr 24, 2008 | 12:10 PM
tommy2go's Avatar
I'm using 660 injectors and a reflash on my ecu. I had to sent the damn thing to Turbonectic to reflash.
Old Apr 24, 2008 | 12:11 PM
tommy2go's Avatar
6 speed
Old Apr 24, 2008 | 12:17 PM
tommy2go's Avatar
I had one degree colder on the NGK spark plugs the fuel pump we had to take my stock one out and put in the step by step of upgrading to turbonectic fuel pump. We had to drilled holes to get better fuel flow. I can smell rich fuel running on the car.
BAD430BENZ's Avatar
what year is it ?
Old Apr 24, 2008 | 12:18 PM
tommy2go's Avatar
2003 over 80,000 miles
Old Apr 24, 2008 | 12:40 PM
SDGeneralCounsel's Avatar
For one your injectors are too large. For two, you should not be running the TN kit with just a reflash.
Old Apr 24, 2008 | 12:51 PM
tommy2go's Avatar
what kind of ems do you recommand? I just checked it again its 380 not 660
Old Apr 24, 2008 | 01:13 PM
Black Guy's Avatar
We use turbo xs utecs and deatsch werks 600cc injectors on our turbonetics set ups.
Old Apr 24, 2008 | 03:54 PM
nyqueenz's Avatar
I know this my sound out there... But take your intake pipe of and clean your throttle body. you may carb build up around the butterfly.
Old Apr 24, 2008 | 03:56 PM
nyqueenz's Avatar
Yea 600 are pretty big injectors for your setup.. (kinda ova board)
Old Apr 24, 2008 | 08:48 PM
Jtrain's Avatar
Easy-
what kind of BoV do you have? The spring is probably to light- Get a HKS SSQV
