VORTECH INSTALL II W/DYNO
Old Apr 8, 2004 | 07:50 PM
DbSQjunkie's Avatar
A FEW MORE VORTECH INSTALL PHOTOS
<P ID="edit"><FONT class="small"><EM>Edited by DbSQjunkie on 04/08/04 05:22 PM.</EM></FONT></P>
Old Apr 8, 2004 | 07:52 PM
DbSQjunkie's Avatar
Re: VORTECH INSTALL II
MORE PICS.
Old Apr 8, 2004 | 08:11 PM
DbSQjunkie's Avatar
DYNO RESULTS !
Old Apr 8, 2004 | 09:37 PM
kwakman's Avatar
ooh, dangerous dip after 6krpms in a/r ratio. I'm sure a little more tuning will get more power out of it.
'03 G35c DG/G 6mt, full options
Old Apr 9, 2004 | 01:23 AM
protocav's Avatar
that is actually too rich...not too lean.
Old Apr 9, 2004 | 03:02 AM
Tory's Avatar
Dude the instal looks almost as sweet as the dyno sheet.
2004 Sedan
Black/Willow
Premium w/ splash guards
Clear Corners, Z-tube
Old Apr 9, 2004 | 07:19 AM
zimbo's Avatar
Congratulations! Looking at your dyno sheet, I'm guessing you had the SS box custom programmed. Is that so?
If so then one observation: obviously, you would benefit somewhat from slightly decreasing the amount of fuel in the R4 map at 6500. It's probably good to have the A/F at 6500 be slightly less than 12 but there's no need for it to be at 10.
Also, did your installer/tuning change the amount of timing being taken out? It's a bit odd to me that your HP curve begins to get really jumpy above 5500 rpms.
--Steve
Old Apr 9, 2004 | 04:19 PM
lz350gt's Avatar
Does your dyno indicate 323 rwhp? I thought the numbers should in the 350-360 range?
Old Apr 9, 2004 | 09:11 PM
DbSQjunkie's Avatar
Reply to Steve,
No. That is out of the box tuning. Just did the dyno to make sure all parameters were safe.
Software from Split Second should be here Monday or Tuesday. Then It'll be time to "fine tune".
I had a lengthy talk with the engineer at Split Second he's very sure there is more SAFE horsepower available in the timing parameters. He says their defaults are very conservitive given the low octane and oxygenated fuels used on the west coast. His explaination for the irratic nature of the graph at high RPM was due to the overprotection of timing retard proportional to boost pressure.
Old Apr 9, 2004 | 11:23 PM
zimbo's Avatar
I'd sure love to get your out-of-the-box map since I don't have a copy of mine anymore (long story). In exchange I would gladly send you my custom maps for comparative purposes--however, your fuel map looks really good except the value at 6500 rpms. So, yeah, it's probably a timing thing.
Send me a PM if you're interested in the swap.
--Steve
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
gatorglaze
Sep 10, 2015 12:03 PM
n2fooz
Sep 4, 2015 07:46 PM
Machine Head
Sep 4, 2015 07:22 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
