Lets share our utec maps
Old May 4, 2008 | 01:28 AM
N/A Project's Avatar
-2006 IP GT350-
This is just so wrong...
Using tuned map from another car can greatly harm your engine because there are many variable details added to it.
Your engine costs alot more than a tuned map.
JJ
Old May 4, 2008 | 04:17 AM
Skaterbasist's Avatar
Retired SuperMod
Waiting for someone to screw something up... *Boom*
Old May 4, 2008 | 08:25 AM
Zcon's Avatar
lol yea i wouldn't use that map if i were you .... :-D just letting you check out someone elses map
Old May 4, 2008 | 08:54 AM
itpro2002's Avatar
Was not planning on using just comparing settings.
Old May 11, 2008 | 12:13 AM
beastie's Avatar
I download music but I guess I feel different about this because:
A) I like and respect my tuner (Sharif@Forged)
B) Like others said no 2 engines are the same and my tune would 100% blow your engine.
C) These are custom tunes that good tuners spend a lot of time and our $$ on. Not some UniChip BS from the factory.
BTW, if you can't understand the UTEC code you shouldn't be messing with it. It's super easy...
Old May 12, 2008 | 03:40 PM
2slo2bfurious's Avatar
I don't see why posting maps is wrong, its not like there some special code inside each map, you add a little timing here, take away some fuel there, change a few numbers here. So what? if this tuner uses more timing and more fuel than another vice versa does it make a difference if the end result is the same? A solid tune is a solid tune is a solid tune. Is there some magical way to tune a G35/350Z UTEC? NO..... Being so secretive about maps is just retarded. Even if you posted all the maps from a tuner, you will still need them to tune your car anyways, they're the ones with the dyno. Yeah maybe you get get close with the free maps, but being spot on, you really need a dyno + tuner OR pay for longer dynotime to play with it unless you really know what your doing (which you wouldn't need a tuner or free maps anyways in that case).
Old May 12, 2008 | 04:03 PM
frankie945's Avatar
+1 subcribing
Old May 12, 2008 | 07:15 PM
itpro2002's Avatar
can argue this forever but no point don't want to share don't post comments! That is what I asked in the begining NO NEGATIVITY
Old May 12, 2008 | 07:57 PM
G37Rider92649's Avatar
haha serious, as simple as that
but anyways hows the install coming along? started yet? any updates?
Picture Share
Feb 4, 2018 12:41 PM
Blue Dream
Dec 5, 2015 10:56 AM
master111
Oct 6, 2015 01:36 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
