more tq with vortech??
Old May 6, 2008 | 04:21 PM
shabarivas's Avatar
^^ and what about the qtr?
Old May 7, 2008 | 12:09 PM
str8dum1's Avatar
any time you pop over 4k+ rpms with it WOT, you should really jump. It must reach the volumetric efficiency of the blower around then
Old May 7, 2008 | 01:32 PM
SDGenius's Avatar
try addin' an MREV2 to the mix
Kinetix SSV(intake runners, good for FI)
Cosworth plenum($$$)
Strup or Stillen(2 torquiest i've seen) headers w/stock cats*
stock headers w/HFCs*
(*)some people runnin' SCs have problems holdin' PSI when they're exhaust set up has "too much" added flow
Old May 7, 2008 | 01:41 PM
sentry65's Avatar
I wouldn't do the SSV or cosworth without headers and/or cams. Otherwise you'll probably lose power
haven't done it
Old May 7, 2008 | 06:39 PM
superchargedg's Avatar
Originally Posted by deanfootlong
well how much power are you making? im making 348 tq and 405 whp with a 3.12 pulley.
i still have stock headers and cats. i want to get headers and cats but am scared i'll make enough power to blow it up once i put those mods on.
Somebody gave you a nicely corrected dyno sheet for that power on a 3.12 pulley on a dd dyno.Thats all i will say about that bs power number.
Old May 7, 2008 | 06:52 PM
clifftrail's Avatar
His numbers aren't out of line for the 3.12 pulley. Just have to be willing to rev that high to get them. A 3.12 will crack 400 w/good tune.
Old May 7, 2008 | 07:16 PM
EricIsKlumzyee's Avatar
The power curve is as is you can change how the curve looks using a combo of intake runner length and headers..
But because of physics.. your S/C wont make any more power then what you have now unless you spin it faster with a smaller pully.. What you have control of is your curve.. but the general result is loss of hp to increase tq.. (only way that this is false is if you're current combination of intake manifold / header isnt at max effiency or is a bad combo)..
Kentix.. thats junk dont even try it.. you can mess around with your plenum.. by swaping spacers around but bigger plenum = more volume = more loss in low end (tq) more potential for high end....
PM me your list of MODs and dyno graph and i'll give you my .02
- Eric
Old May 7, 2008 | 08:31 PM
sentry65's Avatar
- Eric
i think you have it backwards with the plenum
smaller plenum volume is better for high rpm power while larger plenums are better for midrange power. At some point the air velocity becomes more important than the amount of it that can be stuffed into the manifold at a given moment
btw, the SSV has shown gains on just about everyone who has switched headers, cams, or has headwork.
Pretty much every turbo setup that uses the stock cams with either stock or short /small exhaust manifolds (greddy, APS, PE, JWT, most TN setups, etc) has lost power with the SSV
Old May 7, 2008 | 09:00 PM
ttrank's Avatar
Grocery getter
Originally Posted by Audible Mayhem
built motor twin turbo!!
Could not agree more!!!!
Old May 7, 2008 | 09:13 PM
By increasing the plenum size you will see your power curve shift higher and higher (+top -low end), Yes a small spacer will increase some mid-top range but if you continue any bigger you'll see a more noticeable loss in low end and more gains in upper. Eventually you'll stop gaining and loosing.. Velocity directly effects low-mid performance.. especialy true to you guys because your S/C.. the mechanics of your runners and plenum will directly effect how much power you produce in low end.. when you enter higher RPMs certain things no longer apply and all that matters is how much air you can push in and out of the engine.. bigger plenum will create more mid-upper power because your plenum can now store more air to push into the cylinders... its a little different when you're turbo because you get to force air in as soon as you spool.. a little different from s/c
hope it makes sense my heads a little x.x from the day and i probably jumboed up some words
Old May 7, 2008 | 11:21 PM
cchaorule's Avatar
around how much does it cost to install cams on our cars?? im thikning about getting some cams next
Old May 8, 2008 | 12:33 AM
SDGeneralCounsel's Avatar
OP just get rid of your damn bling dubs and your car will feel a hell of a lot faster lol
Also, you are running the stock pulley for the rev up kits so you haven't begun to fully tap the power on that thing. I don't want to insult you but you sound like you are running the standard kit with really no other engine work, more boost or anything else. you are going from mild with a simple vortech kit, to extremely wild with a built motor in my opinion. I say find a middle ground for now
Old May 8, 2008 | 01:50 AM
urban's Avatar
1200 for the cams I want and about 900-1000 for install I had it done once on my old engine.
Old May 8, 2008 | 03:45 PM
  #30
str8dum1's Avatar
ya doesnt make sense to do cams without building the motor.
