Vortech Rattle
Old May 19, 2008 | 01:02 AM
sentry65's Avatar
going with a smaller supercharger pulley will also reduce the noise and spin the blower faster.
I don't think it'd be enough to completely kill it though like raising the idle would
Old May 19, 2008 | 12:04 PM
joe603's Avatar
Can you post a sound clip of the noise?
Old May 19, 2008 | 02:52 PM
FastDontLie's Avatar
...we dont need roads...
Originally Posted by sentry65
going with a smaller supercharger pulley will also reduce the noise. I don't think it'd be enough to completely kill it though like raising the idle would
+1 Smaller pulley - more boost - less rattle!
Old May 19, 2008 | 08:34 PM
ForcFed's Avatar
What supporting mods do I need to go one pulley smaller? Currently only have a Borla cat-back.
Old May 19, 2008 | 10:49 PM
SDGeneralCounsel's Avatar
either a better FMU or meth injection. The guy that previously owned my kit had been running a smaller pulley for years and just a meth injection system and he produced a reliable 412 whp
Old May 19, 2008 | 10:50 PM
express705's Avatar
test pipes
Old May 19, 2008 | 10:53 PM
Originally Posted by express705
test pipes
to run a smaller pulley? Wrong!!!
Old May 23, 2008 | 12:32 AM
Triji's Avatar
It is normal, I usually left / right foot at lights to bring my rpms to 800 which gets rid of it. No need to worry, I now have 50K miles on my blower and no problems at all... I had the rattle from day one of install as well. No mods needed to go to a smaller pulley really, I put on the 3.12 from the 1st day as well with no issues at all and I am thinking of putting the 2.8 pulley on sometime soon which I have sitting in my garage... I have a meth kit as well but have not installed that yet either.
Old May 23, 2008 | 07:44 AM
HEGONE's Avatar
Is this the rattle you talk about? If so, TOTALLY normal.. this is my vortech video and it was taken about 2 days after i installed it. I raised my idle to 900 and its fine now.
Old Feb 10, 2010 | 01:16 AM
bradgab's Avatar
why there is Vortech gravel noise
I am looking into FI for my car. I have been doing some research on this issue and emailed vortech about it...no reply. The vortech supercharges is basically a pump. So there are lots of things that effect the opperation of a pump. A pump does not "suck" it creates a difference in pressure. If we use the same principals as a centrifical pump, other then the fluid is a gas rather then a liquid. I figure this "noise" is one of the following:
1)Some type of cavitation in the system on either the suction side or discharge.
2) The "pump" not operating in its Best Efficiency Points (BEP). All pumps have a pump curve where the best opperation is between 2 point on efficiency curve. Operation outside of the BEP produces cavitation. Increaseing the RPM moves the pump up it's BEP curve to produce a higher flowrate therefore reducing the "noise"
3) Bearing clearence issues
The reason I figure it 1 of the above is because I troubleshoot industrial equipment for a living and that gravel sound you hear is usually a sign of caviation of the pump opperating out of its BEP...I could be wrong but I cant find anther good answer for this
Old Feb 27, 2010 | 06:45 PM
mjd240's Avatar
My 05 G35 coupe is set up with a Vortech and and smaller pulley. The pulley did help take away the rattle some. Then I got a new twin disk clutch that makes all kinds of noise at idle. The car loves 10 - 27 degrees. Sounds Jet Solid. But above 50 degrees and after a 10 minute warm up, I will hear some noise.
seagrasser
May 3, 2022 09:43 AM
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
TNRocker
Sep 21, 2015 08:36 AM
socaldavid
Sep 5, 2015 04:35 AM
n2fooz
Sep 4, 2015 07:46 PM
