Have greddy TT, adding test pipes. Do i need a re-tune?
Old May 20, 2008 | 11:39 PM
YellowCelica_GT's Avatar
Hi guys, I was just wondering. I have the Greddy TT kit with a Greddy SP2 exhaust. I was just wondering if i need a re-tune if I add test pipes to my setup??
Old May 21, 2008 | 12:12 AM
str8dum1's Avatar
depends if you want to see any gains on a dyno. if you are tuned spot on with cats, you most likely need a retune to see the gains with the test pipes.
will a retune make a difference to the butt dyno? most likely not. but louder is faster right
Old May 21, 2008 | 12:17 AM
SDGeneralCounsel's Avatar
it would help since tp and exhaust will cause your car to run more lean. to maximize power out of your new mods you would need a tune. It is however not necessary.
Old May 21, 2008 | 04:39 AM
G37Rider92649's Avatar
Yes
Old May 21, 2008 | 08:01 AM
App6MT's Avatar
Littering and...
[QUOTE=Lawy'dU]it would help since tp and exhaust will cause your car to run more lean. QUOTE]
This would be the main reason you would want a tune. You would make more power by leaning out your tune however you are running the risk of detonation.
Old May 21, 2008 | 10:12 AM
SlideFox's Avatar
If it was tuned with the exhaust, then no. If you don't want to, but you can run into detonation if you don't
Old May 21, 2008 | 10:27 AM
Hi-TechG35's Avatar
Yes you need a tune. Any slight modification can be the difference between life and death of your motor.
Old May 21, 2008 | 11:10 AM
bullitproof's Avatar
my shop told me i would lose 30whp going from test pipes back to cats. so i would say yes.
Old May 21, 2008 | 11:48 AM
sharif@forged's Avatar
Definately get it to the dyno to check. In almost all cases, you will end up running a little bit more boost, and a little bit lean (due to the reduced back pressure). Shouldn't take but a few pulls to richen it back up for safety.
Bolting on test pipes, and driving away, is a risk not worth taking.
Old May 21, 2008 | 01:45 PM
thanks for the input guys!
i actually am running on a very conservative tune right now (running pretty rich)
will the test pipe lean things up a bit and just require a lil of bit of tuning?
Old May 21, 2008 | 01:59 PM
EricIsKlumzyee's Avatar
yes re-tune.. you'll make more power with the TT set up too when you run test pipes =)
you'll love it, but retune for sure.. why spend the money to mod if you're not going to take the full advantage of it?
Old May 21, 2008 | 05:37 PM
superchargedg's Avatar
Spend the money and retune as to not take any chances.I only picked up about 11rwhp but i gained 23rwt with the test pipes and Dave at FunctionTuned had to make a few adjustments to the original tune.
Old May 21, 2008 | 06:38 PM
nyqueenz's Avatar
helix TP
I also wanna add to this...
I'm doing a greddy TT setup with the Evo TT exhaust.. I also have Helix test pipes which are 2.5" dia... Is this a good for my setup meaning the test pipes it self.. They have no resonators so its a st8 pipe..
Old May 21, 2008 | 07:17 PM
^ Thats awesome for TT for noise level and performance.. course guys with giant turbos would go bigger
Old May 21, 2008 | 07:54 PM
do the 3" test pipes if you can.
