Turbo ate rubber!
Old Jun 29, 2008 | 11:40 PM
nuclearcarnie's Avatar
Turbo ate rubber!
So I was out for an evening blast with an old friend, we were in the boost when all of the sudden I hear a screach and lose power. I find an extremely fine red dust under my hood and upon furthor investigation I find that my turbo pulled a loose rubber diameter reducer that was on my K&N filter into its blades. It ate about 1/8 of the grommet and sprayed a fine red rubber dust through my intake piping and innercooler...what a freakin' mess! Anyway, I don't believe that there will be any internal engine damage, the car ran for a couple of minutes afterward while getting to the nearest parking lot and the dust is so fine and soft that you can't feel its texture between your fingers. The turbo on the other hand has me more than worried, I really don't know how durable it is. I have a hard time believing that it would survive such a shock. I can feel with my finger and see the blades and they look and feel normal, they also spin freely. Could it have survived?
Man this sucks. I finally found a good place to install a filter and something stupid like this happens.
Any input on survivability and maybe cost of getting the turbo rebuilt would be appreciated.
Old Jun 30, 2008 | 08:35 AM
6spG's Avatar
I would clean out all the piping and IC. Check that the turbine fins are in tack and that there is no contact w/ the housing.
Old Jun 30, 2008 | 01:03 PM
Meatshackle's Avatar
Deep Sea Moderator
That's pretty strange. I'm still trying to picture what part it ate. My K&N goes on the outside of intake piping and is hoseclamped.
Old Jun 30, 2008 | 01:16 PM
rookie's Avatar
So the coupler holding the filter to the pipe got sucked in and shredded? hmm, I would check to see how far into the motor that shredded silicone got. If it's in your plenum I'd check the motor before worrying about the turbo.
Old Jun 30, 2008 | 01:54 PM
Audible Mayhem's Avatar
that really sucks...
Old Jun 30, 2008 | 03:08 PM
Deep Sea Moderator
^ literally
Old Jun 30, 2008 | 04:35 PM
urban's Avatar
I agree I would be more worried about my motor right now. The blades may feel fine and spin freely but it would be hard to tell if any were bent which would change the effect they have on boosting.
Old Jul 2, 2008 | 11:36 AM
Alright, here's the deal.
Took apart the entire system from the turbo to the intake, found a couple of big chuncks in the intercooler and everything down stream of that was a fine red dust. Also disassembled the intake, sucked and blew it out. After I was sure the system was clean I put it all back together and started the car. Because of the location of the turbo (bad clearance problems) it is very difficult to see the inlet blades so I chanced a trip around the block. The motor runs fine the turbo sounds like a wounded dianosaur.
So now I have removed the turbo and sent it back to turbonetics for a rebuild. **** happens
All of this was no ones fault but my own but I can't help but think that if the install shop would have just finished the job in the first place, none of this would be an issue.
Old Jul 2, 2008 | 12:14 PM
GreenGoblin's Avatar
The goblin resurrection
yes that really sucks
Old Jul 2, 2008 | 12:22 PM
kevino002's Avatar
I had this happen to my GT35R on my civic (filter failed on the turbo inlet), motor was fine but the turbo need a rebuild. sucked but I was just happy that a 10k motor was okay.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
dcsbh1
Oct 1, 2015 03:15 PM
mbe32
Interior
Oct 1, 2015 09:47 AM
Paragham
Sep 15, 2015 12:04 AM
