Twin turbo question?
Old Aug 1, 2008 | 11:54 AM
specialist's Avatar
Question Twin turbo question?
2003 g35 coupe
I am going to buy a greddy tt
i have bought pistons and rods. My question is do i really need to get the whole valve train(part of it or not of it?)
If i do springs/ shims and retainers do i need valves too or oem ok.
I want approx 500 and 350 daily.
Old Aug 2, 2008 | 04:52 AM
TTG35forT's Avatar
Originally Posted by specialist
2003 g35 coupe
Unless you have done so already, read this sticky:
https://g35driver.com/forums/forced-...ion-noobs.html
Whether you need new springs etc. depends in large part on what cams you run. You do not necessarily need to run aftermarket cams to meet your hp goals, but the right cams will probably make it easier. Generally speaking, stock valves are adequate for 500 hp.
Also, based on your question, I'm assuming that you are not a VQ expert. It's probably worthwhile to pick a qualified VQ tuner and to work with that tuner to select the appropriate components to achieve your goals. Also, there is alot of good information here and at the My350Z.com forum. It will be well worth your while to do some research.
Drifter2090
Dec 26, 2015 12:10 AM
DigitalDeviant
Engine - Intake/Fuel
22
Dec 4, 2015 10:27 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
