My Greddy Build Thread
Old Aug 24, 2008 | 11:33 AM
  #196
escobar929's Avatar
nice work danny, cant wait to see the number you put down
Old Aug 24, 2008 | 11:36 AM
  #197
express705's Avatar
409
Old Aug 24, 2008 | 01:51 PM
  #198
freddie07's Avatar
^^thats dyno or just guessing?
Old Aug 24, 2008 | 01:57 PM
  #199
express705's Avatar
its waht its gonna be.
Old Aug 24, 2008 | 02:06 PM
  #200
freddie07's Avatar
oh ok
Old Aug 24, 2008 | 07:48 PM
  #201
XKR's Avatar
XKR
updates
Old Aug 25, 2008 | 08:42 AM
  #202
GreenGoblin's Avatar
The goblin resurrection
Updates:
Car is running, and it is running pig rich with the injectors and no tune as of this second. I mounted the overflow coolant tank behind the grill, to clean up the engine bay a bit more. I have a greddy coolant overflow tank that I need to install, blow off valve is causing the car to stall right now need to double check the spring pressure. Car idles with out the bov hooked up so I am lead to believe I got the wrong pressure spring. Other than that I bleed all systems including the Dm2 coolant kit, looks much better without all those hoses running around in there.
I know that this thread is worthless with out pics. I will try to get them uploaded tonight.
Thanks for the support guys.
I would love to make 409 whp with Jeremey time will tell.
Old Aug 25, 2008 | 08:49 AM
  #203
express705's Avatar
fail
  #204
escobar929's Avatar
nice bro
409 shouldnt be too hard to get
Old Aug 25, 2008 | 01:40 PM
  #205
_jb's Avatar
_jb
Photographer
Super job on the builds, guys...
Jeremy will do a good job on the tune... This baby should fly...
Old Aug 25, 2008 | 06:23 PM
  #206
Andrei's Avatar
Would it not be cheaper and better to tune it on the street?? Because that's what I'll be doing with mine Do a 3rd gear pull on the street and tune. I do 3rd gear pulls on the highway all the time and I only hit about 90MPH or less.
Just asking
Old Aug 25, 2008 | 08:31 PM
  #207
freddie07's Avatar
^^That is the cheap way. To get true readings you must go to a dyno. Plus highway pulls are never safe for you or the people around you.
Old Aug 25, 2008 | 10:02 PM
  #208
2slo2bfurious's Avatar
^^Better if you have both, cheap is the wrong word. You're forgetting how much longer it takes to go up and down a highway at different rpms, tps, etc. all the while using gas!! On a dyno it's pretty much the only way you can clean up the powerband. WOT tuning on the road is about all you can really rely on, most of the time, that is if you have the right sensors to keep it safe.
On the dyno you'd be tuning somewhere in between RBT/LBT, on the street you're guessing by using your AFRs, EGT's, knock, etc..... either way one compliments the other..... that is the right way.
Of course if you don't really race or anything and just like to WOT every now and then road tune will suffice... lol.
Can't wait to see the Greengoblin burn some rubber!!
Old Aug 27, 2008 | 08:06 AM
  #209
MADMAXSS's Avatar
Good Luck Danny on your tuning and hope everything turns out well can't wait to see it at the next meet or sooner.
Old Aug 27, 2008 | 11:22 AM
  #210
APSMike's Avatar
Congrats! Good luck with the tuning. You should hit 409 without a problem.
