I NEED more power!
Old Sep 25, 2008 | 01:29 PM
TheDude's Avatar
I NEED more power!
A lot of you already know i've got the vortech full kit on my 05 5at, it dynoed on a dynapack at 387 rwhp. Last night I took it to the track for the first time thinking it would be LOW 13's possibly. It was about 60-65 degrees out and I ran consistent 13.6 second quarter miles.
My question is, is that about right 13.6? If so I want more power!! now I know the smaller pulley will give me more power but ideally I want to run high 12's low 13's what do I need specifically for that...
Old Sep 25, 2008 | 01:30 PM
TheDude's Avatar
also how much time do you think I will shave off my time by getting Volk 19's that are probably much lighter than my 20" axis pentas...
Old Sep 25, 2008 | 02:26 PM
FI'ed G's Avatar
Post you timeslip so we can see what your car is capable off... 60', 1/8 and 1/4 mile Trap... I'll tell you this much the 20's didnt help you.
Old Sep 25, 2008 | 02:35 PM
khundkar's Avatar
I ran with him on the first try at the track last night. It was my first time drag racing.. but i managed to get 14.7 against him.
Old Sep 25, 2008 | 02:41 PM
superchargedg's Avatar
Somethings not right there as i did better then that with my old stillen stage4 setup.
1.20's def dont help
2.bad track prep?
3.what was your 60' time
4.did you spin the tires to much.
Old Sep 25, 2008 | 02:46 PM
Hi-TechG35's Avatar
I ran shiety times up there a few weeks ago but I had all that extra weight (system, wheels etc). Like he said 20's didn't help any. So you got the boost fever now....lol.
Old Sep 25, 2008 | 02:47 PM
Hi-TechG35's Avatar
Hey I thought you said you were a Sunday Driver K...what were you doing tracking Good Time though!
Old Sep 25, 2008 | 02:48 PM
FI'ed G's Avatar
2.bad track prep?
/\ Can you post your 60's and trap? Also what was the Temp/Humidity?
Old Sep 25, 2008 | 02:50 PM
SDGeneralCounsel's Avatar
you were the dude that had incredibly high numbers on a stock vortech full kit right?
If so, your numbers are off and you now know that for sure.
1. Time for more boost, lighten the weight, different suspension settings, different rear end+lsd, different wheels and tires (big blingy volks are generally not light unless you have Te's or Le's, and even at that 19's are too large), etc.
Old Sep 25, 2008 | 03:21 PM
Well since that was well over a year ago i do remember some.
1.1.99 60' my best ever
2.13.41 at 107 im pretty sure on mph
dont remember the rest and i havent had the stillen for a long time.I almost forgot this was with 18's with khumo 275/40/18 spts.
Old Sep 25, 2008 | 03:50 PM
TheDude's Avatar
Temp like I said was cold anywhere from 58-67 degrees.
Virtually no spin in either of these runs, tires were pretty warm, my two worst runs were 14 seconds flat, tire spin and I didn't realize I had VDC on and it kicked in in the begining.
Last run, best run...
R/T - .342
60' - 2.219
330 - 5.909
1/8 - 8.923
MPH - 81.63
1000 - 11.483
1/4 - 13.646
MPH 103.46
First run, second best run...
R/T -.542
60' - 2.272
330 - 5.965
1/8 - 8.964
MPH - 82.03
1000 - 11.515
1/4 - 13.689
MPH - 102.95
Old Sep 25, 2008 | 03:54 PM
GreenGoblin's Avatar
The goblin resurrection
need to get that 60 ft down
Old Sep 25, 2008 | 03:56 PM
TheDude's Avatar
how? its AT? I mean I really don't have TOO much control, I know my rection time is high too but this is the second time i've gone to the track.. EVER.
Old Sep 25, 2008 | 04:07 PM
escobar929's Avatar
next time you goto the track put the stock wheels on w/ some drag radials
that will help a lil but you gotta work on your 60ft, what rpm are you brake torquing at?
Old Sep 25, 2008 | 04:08 PM
escobar929's Avatar
BTW, which pulley are you using?
