Has anyone put thicker headgaskets to lower comp.?
Old Dec 16, 2008 | 10:56 PM
GT-ER's Avatar
I've seen many people do this to allow stock N/A engines hold more power without having to forge the engine. How about the VQ? Anyone ever put thicker gaskets to lower compression to make more power on the stock long block?
Old Dec 16, 2008 | 11:05 PM
Shakuya88's Avatar
Lower the compression and you will lose power. I can maybe see doing it to aid when boosted but not for an N/A engine ever.
Old Dec 16, 2008 | 11:08 PM
GT-ER's Avatar
I meant with boost...sorry for not specifying. This is the forced induction section though.
Old Dec 16, 2008 | 11:12 PM
Shakuya88's Avatar
I usually don;t pay attention to that...haha but yeah, that would help but again, never seen it. One thing you CANNOT DO is put 2 head gaskets together. If you could find one it would help a bit.
Old Dec 16, 2008 | 11:21 PM
Glex25's Avatar
Administrator
You can't do this to the VQ motor.
Front timing chain cover will not line up.
Old Dec 16, 2008 | 11:34 PM
Mr_pharmD's Avatar
not sure why someone would want take out the motor to just replace the headgasket and leave the block stock? This isnt a honda where u can just pop off the head when it's still in the engine bay.
Old Dec 17, 2008 | 03:57 AM
nyqueenz's Avatar
what is the thickness of the hg?
Old Dec 17, 2008 | 06:56 AM
GT-ER's Avatar
Wow...I thought you could. Ouch.
Then I agree it would be useless.
Old Dec 17, 2008 | 02:35 PM
GreenGoblin's Avatar
The goblin resurrection
It was mentioned before but it cant be done due to the design of the vq.
Old Dec 23, 2008 | 09:56 AM
CreativeDesignZ's Avatar
stronger than stock?
Old Dec 23, 2008 | 10:58 AM
thom000001's Avatar
you are still limited in hp due to the rods. All's higher compression and boosted means is you can run less timing and need higher octane fuel (in general). But you are still limited to 400-430rwhp'ish on stock rods.
Alex Koss
Oct 29, 2021 12:53 PM
rezendvous420
May 31, 2020 01:26 PM
mann1961
Aug 9, 2015 08:44 AM
Jadenkid22
Jul 14, 2015 12:33 AM
