Gassss
Old Feb 5, 2009 | 01:29 PM
superchargedg's Avatar
I get about 320 miles out of a tank while boosting about 50% of the time.
Old Feb 5, 2009 | 06:56 PM
G37Rider92649's Avatar
You Pusssies jk jk lol I had 9-10mpg Atleast I ain't one of those boosted people with 20mpg + status, I don't know wtf they even went boosted for
Old Feb 5, 2009 | 07:51 PM
GeeRider's Avatar
you get that much , im in canada so its kms over here and i can barely get 400 kms out of a tank with my stock G35, thats about only 250 miles. Are tanks in the us bigger or something LOL
Old Feb 5, 2009 | 09:01 PM
GTreeFive's Avatar
I get 15-18 at 6psi - conservative tune bone stock and vortech.
If $ is so tight that you need to worry about mpg, FI isnt for you bc boost is a gateway drug.
An M3 V8 can get 19mpg and a prius (worse environmental impact to produce) can get 17mpg its how u drive it - Top Gear proven
Old Feb 5, 2009 | 09:29 PM
MadMatt1144's Avatar
Haha if you gotta ask you probably can't afford it...nah just kidding but honestly it'll probably be in the 9-14 range...tough but hey perks of being fi
Old Feb 5, 2009 | 09:34 PM
GeeRider's Avatar
lololol naw moneys not tight, just wondering since the g's gonna be ma daily driver.
Old Feb 5, 2009 | 10:24 PM
FI'ed G's Avatar
You think about gas but you never think about blowing your motor?
Old Feb 5, 2009 | 10:25 PM
GeeRider's Avatar
LOL ya bout that, if i have a semi conservative tune is it safe or is der still always risks
Old Feb 5, 2009 | 10:31 PM
FI'ed G's Avatar
your priorities are upside down (gas first then motor safety second)... lol depend on many factors but FI on stock block can be safe
Old Feb 5, 2009 | 10:32 PM
GeeRider's Avatar
ye im messsed up like that lololol, and so if i have it set to approz 8 or 10 psi, i can floor the car without worrying rite?
Old Feb 5, 2009 | 11:28 PM
thom000001's Avatar
Actually if you use stock NAV you will be WWWWWWWWAAAAAAAAAAYYYYYYYYYY off
That is based on load and vaccuum. no more vaccuum when under load when FI, its positive pressure. I love watching mine while in boost and see the leaf peg at 40mpg and the mile till empty starts climbing lol
The instantaneous mpg still works when you are just like cruising on the highway at a constant speed.
I don't even want to tell you how low mine gets on the 30psi tune lol
tom
Originally Posted by FI'ed G
Are you using your Navi to estimate this? Nav is not going to be accurate once you mofied your fuel system because your injector is going to be bigger or if you have a stock injector and FMU then fuel pressure is different. You guys are lying to your self if you believe you get more mileage with FI!! If you are not boosting then maybe but if you are on boost then there is no way in hell because your A/F alone is going to be in the 11's and there is also more air being pumped in the motor.
OP, gas mileage is the last thing you should worry about with FI!!! If that is your main concern then go get a 4cyl civic!!
Old Feb 5, 2009 | 11:48 PM
GeeRider's Avatar
what kind of numbers r you getting at the wheel with the 30psi tune :|
Old Feb 6, 2009 | 12:17 AM
urban's Avatar
I think this topic was covered over a year ago, just search and you will get your answer.
I get 21 mpg with my TT setup and that is mixed driving with small amounts of boosting here and there.
Old Feb 6, 2009 | 02:24 AM
thom000001's Avatar
made 769rwhp with very little timing only on 110 leaded......has about 8psi and a lot of timing in it still for C16 fuel......we may go for the stock sleeve record before xkr finishes his new setup lol..
tom
Old Feb 6, 2009 | 08:12 AM
  #30
djamps's Avatar
I got worse mileage than that before I went TT. Did you swap your internals out with a Prius?
