1150rwhp, Sound Performance raises the VQ power record even higher!!!
Old Jul 8, 2009 | 07:19 PM
  #61
tiguy99's Avatar
Originally Posted by WhosUrBuddiee
Sad part, it will probably still run 12s
WRONG.....you missed the part that says the car runs low 9s
Old Mar 11, 2010 | 12:52 PM
  #62
Andrei's Avatar
Quick update to this thread. For people who did not know the SP 350z is stock displacement at 3.5L with a 9000RPM redline and 1248WHP/900rwtq on a mustang dyno.
Old Mar 11, 2010 | 12:54 PM
  #63
thom000001's Avatar
90% accurate.....was 1248rwhp on a mustang dyno.
Motor is currently being redone, and larger turbos going on too (yea 1248rwhp isn't enough bring on the 76mm billets!!!!!)
tom
Originally Posted by Andrei
Quick update to this thread. For people who did not know the SP 350z is stock displacement at 3.5L with a 9000RPM redline and 1248WHP on a dynojet. Probably 1100 whp on a dyno dynamics.
Old Mar 11, 2010 | 01:11 PM
  #64
str8dum1's Avatar
from all the dyno's i've seen, mustang is the closest to a Dynodynamics.
dunno how they plan on fitting those 76mm in there. 62s with E covers were tight enough
Old Mar 11, 2010 | 01:58 PM
  #65
Andrei's Avatar
tom
1248 whp on a Mustang dyno is really impressive. Is there any progress pics of the motor being redone?
What are the expected results with twin 76s? 1400+?
Old Mar 11, 2010 | 02:03 PM
  #66
thom000001's Avatar
whoops dislexia kickin in lol.....67's not 76's lol
Tom
Old Mar 14, 2010 | 11:49 AM
  #67
ska12's Avatar
how can that not get past the 12's, not gripping or something?
Old Mar 14, 2010 | 12:05 PM
  #68
CandlestickPark's Avatar
ill Sedan
Old Mar 14, 2010 | 11:29 PM
  #69
thom000001's Avatar
Huh?
This car has been deep in the 9's at almost 160mph (with a 6spd) on shakedown runs.....
Tom
Old Mar 15, 2010 | 12:03 AM
  #70
mugen_rsx09's Avatar
Thats sick!
Old Mar 15, 2010 | 12:16 AM
  #71
Tollboothwilley's Avatar
what components did you use in the engine build? This is downright sick!
Old Mar 15, 2010 | 04:26 PM
  #72
G45TT's Avatar
so is this the strongest VQ out there
Old Aug 23, 2010 | 03:11 PM
  #73
Andrei's Avatar
To the top.
They used Pauter rods, stock crank, Injected Performance girdle, and Wiseco pistons they are listen in the vid. Either way this car broke the gear off the oil pump and also sheered the splines off one of the axles, the differential did not break. The axles were aftermarket built and the oil pump was a Revup pump that revved to 9000RPM so it was expected to break.
Old Aug 23, 2010 | 04:25 PM
  #74
whats the solution for a better oil pump - is there one?
Old Aug 23, 2010 | 08:41 PM
  #75
thom000001's Avatar
Not many people are going to be revving to 9k, at least not on a street application. So you should be ok. Remember this car was basically an R&D setup so basically when the motor was on, it was being pushed...be-it 1xxx dyno pulls, or 9sec 1/4 passes at almost 170mph.
Tom
